Wiring For Bar Area - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 12:33 PM   #1
Wiring for Bar Area
I am running a new circuit for my bar area in my basement. I will have probably 3 outlets, some lights plus a mini fridge and maybe eventually a kegerator.
Is 15A ok for this or should I do a 20A. If I do 20A, obviously I need to run 12-2 wire instead of 14-2, but do I need 20A receptacles or are standard ones ok?
jdtox is offline   Reply With Quote
Old 09-24-2012, 01:44 PM   #2
Julius793's Avatar
I would go 12awg and standard outlets are fine.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-24-2012, 02:17 PM   #3
Oso954's Avatar
Rewards Points: 746
If you have a sink in that bar, the receptacles would require GFCI protection if located within 6 feet of the sink.
Oso954 is offline   Reply With Quote
Old 09-24-2012, 05:18 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If you are going through the trouble of pulling a wire, why not pull a 12-3? At least this way it will give you future options...
Check out my bar that I built, (link is at bottom) I only used two circuits, and I have a few appliances.
Old 09-25-2012, 08:33 AM   #5
Code05's Avatar
Rewards Points: 1,104
Depending on which code cycle and your local amendments, circuit(s) may require AFCI protection.
Code05 is offline   Reply With Quote
Old 09-25-2012, 09:09 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you are planning on a kegerator and a mini fridge, I would for sure run two 20A circuits.
Knob & Tube Wiring? cbzdel Electrical 8 08-17-2012 07:33 AM
Outdoor Seating Area JackOfAllTrades Landscaping & Lawn Care 10 02-05-2010 03:01 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
