-   -   Wiring for Bar Area (http://www.diychatroom.com/f18/wiring-bar-area-157837/)
jdtox 09-24-2012 11:33 AM
Wiring for Bar Area
I am running a new circuit for my bar area in my basement. I will have probably 3 outlets, some lights plus a mini fridge and maybe eventually a kegerator.
Is 15A ok for this or should I do a 20A. If I do 20A, obviously I need to run 12-2 wire instead of 14-2, but do I need 20A receptacles or are standard ones ok?
Julius793 09-24-2012 12:44 PM
I would go 12awg and standard outlets are fine.
Oso954 09-24-2012 01:17 PM
If you have a sink in that bar, the receptacles would require GFCI protection if located within 6 feet of the sink.
stickboy1375 09-24-2012 04:18 PM
12 Attachment(s)
If you are going through the trouble of pulling a wire, why not pull a 12-3? At least this way it will give you future options...
Check out my bar that I built, (link is at bottom) I only used two circuits, and I have a few appliances. :)
Code05 09-25-2012 07:33 AM
Depending on which code cycle and your local amendments, circuit(s) may require AFCI protection.
k_buz 09-25-2012 08:09 AM
If you are planning on a kegerator and a mini fridge, I would for sure run two 20A circuits.
