Wiring A Ballast From T12 To T8 - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 07:59 PM   #1
wiring a ballast from t12 to t8
i bought a ge ballast( gem220ts120). the t12 ballast had two reds,blues,yellows.I bought a t8 ballast with the same colors. I wired one blue from ballast to one blue from light tombstone,the same with the other blue.I did the same thing with the two reds,yellows color to color. I have two f15 lamps it is a two lamp fixture. when i turn on the light switch the lamps are dim. If i turn the lamps when they are in the light fixture they come on. And sometimes if i turn the light swich off,on quickly the light will come on.Could it be a bad ballast or wrong wiring.
family is offline   Reply With Quote
Old 05-16-2011, 08:33 PM   #2
Licensed electrician
Rewards Points: 1,478
There should be a wiring diagram on the ballast you should follow.
Old 05-16-2011, 11:40 PM   #3
" Euro " electrician
frenchelectrican's Avatar
For the electronique ballast you will have to follow the wiring diagram on the ballast very carefull and also do you have rapid start or instat start ballast if you have rapid start ballast you should have not much issue change over but instat start ballast the wiring will look diffrent also most case you will have to change the tombstone connection by either shunt them or wire both wires at each tombstone the reason why I mention that due if you only hook up one side of the flourscent pin it can cause premature burn out bulb.
I have see it happend before with instat start when someone forgot to change the tombstone connection. the ballast diagram is the quickest way to indentify it.
Merci,
Marc
Old 05-17-2011, 08:57 AM   #4
joed's Avatar
Rewards Points: 12,388
The wrie colours will NOT match the old ones. You MUST follow the drawing on the ballast.
Ballast wiring, to and neutral wires. Wek Electrical 2 03-03-2011 07:03 PM
Wiring nut type for lamp wire and ballast wire. Wek Electrical 3 03-01-2011 01:59 PM
T8 Ballast Wiring - Help Needed! Mach Electrical 3 07-20-2010 09:33 PM
Help!!!!!! Hps Ballast Wiring whitekid135 Electrical 1 03-30-2008 11:05 AM
Wiring plug to Mercury High Intensity ballast Dustin Electrical 2 05-29-2007 04:56 PM
