Wiring Attic Lights In My Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 05:50 PM   #1
Wiring attic lights in my attic
I'm using 14 gauge wire to wire 3 lights with the first light being a pull switch. I used the wiring diagram attached. When I pull the switch, the first light is bright, the other two lights attached to the pull switch light are dim. What am I doing wrong and how to correct?
KnSMorgan is offline   Reply With Quote
Old 04-13-2013, 05:57 PM   #2
MarginallyQualified
Rewards Points: 2,464
Feed the power through the switch box (then on to how ever many lights).
Consider adding a receptacle at that switch box as well.
Old 04-13-2013, 06:01 PM   #3
I'm actually running the pull switch off of the ceiling light in the garage. Trying to make it simple. What switch box are you talking about? And why are the lights dim beyond the pull switch light?
Old 04-13-2013, 06:06 PM   #4
Rewards Points: 506
We assumed you have a switch box for the switch device, or is the switch dangling from the wires?
As far as the diagram, it looks to me like either will work. Which way did you connect it?
EDIT: oh, now I get it
Old 04-13-2013, 06:14 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you used a lamp holder such as...
There isn't an option to switch additional lights from the pull chain. If you used a different product, I would be curious to see exactly how this is set up.
Old 04-13-2013, 09:11 PM   #6
" Euro " electrician
frenchelectrican's Avatar
I think I pretty much figure it out allready I think someone ran in series that why the last two luminaires are dim.
OP.,
The only two way you can fix this mess is add a correct single pole switch ( I rather run the power in the switch first then go to the luimaires to reduce a chance of getting a connection error )
Or Run all three with pull chain luminaires in parallel format.
I refered that to be controlled by the switch instead of the pull chain keyless sockets.
Merci,
Marc
Old 04-13-2013, 09:57 PM   #7
OK. Well, then can you show me how to wire 3 lights off of one single pole switch?
Old 04-13-2013, 10:07 PM   #8
see below
Old 04-13-2013, 10:09 PM   #9
Ok let me post it.,
(French Verison which I used often )
Here the North Americian side.
After the first luimiare to the next other two luminaires black to black and white to white to other lumianries so it will be the same all the way thru.
Merci,
Marc
Attic Wiring? Ocelaris Electrical 5 04-03-2013 10:20 AM
Help with wiring: 1 switch controlling 2 lights streko Electrical 6 05-02-2012 10:43 PM
Laying attic floor: what should I do about exposed wiring? scool Electrical 6 11-11-2010 12:23 PM
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Running New Wiring to Attic PCC Electrical 12 02-08-2008 05:09 PM
