Wiring Asmoke Detector - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 07:01 PM   #1
Question
Wiring asmoke detector
Hey folks can anyone answer this for me? I am putting in a wired /battery smoke alarm but the best place for me to put it I can only get power from a light switch. The switch only has the 2 wires going to it. The top 1 is hot when the switch is off. Any thoughts?
Mr26t is offline   Reply With Quote
Old 01-04-2010, 07:14 PM   #2
Inspector/Instructor
codeone's Avatar
Sounds like you dont have a Grounded conductor(neutral) at the switch. It wont work to power the smoke detector.
You didnt say how many wires are in the switch box and their colors.
codeone is offline   Reply With Quote
Old 01-04-2010, 07:34 PM   #3
Sorry I'm new at this chatroom thing. There are only 2 wires in the switch box Also this is an older house and the wires are not colored they are the old cloth covered ones. And if you have not guess I'm not an electrician.
Old 01-04-2010, 07:43 PM   #4
codeone's Avatar
Then you do not have a grounded conductor ( neutral ) to make your smoke detector work.
Your line or feed would be up at the light.
Old 01-04-2010, 08:03 PM   #5
ALLLL Nuts... It was a good thought while it lasted. Well now I have to figure out plan B. Thanks for your help.
Old 01-04-2010, 08:06 PM   #6
codeone's Avatar
Where is this room 1st or 2nd floor?
Old 01-04-2010, 08:14 PM   #7
Its 2nd floor
Old 01-04-2010, 08:17 PM   #8
codeone's Avatar
Are you not able to get in the attic above?
Old 01-04-2010, 08:19 PM   #9
There is no attic and to make it worst my walls are plaster.
Old 01-04-2010, 08:58 PM   #10
codeone's Avatar
Why no attic?
You could take the light down lift the box out and fish a wire over to a possible spot. If you messed the plaster up you could ge a medalion that would cover the hole then you mount the light back.
Smoke detector wiring? km2009 Electrical 4 08-15-2009 08:42 PM
Hardwired Smoke detector wiring whisper Electrical 2 07-19-2008 05:46 AM
Fire and smoke detector wiring James Con Electrical 16 03-12-2008 07:24 PM
Residential Smoke Detector Wiring BigJimmy Electrical 2 01-22-2008 11:14 AM
Smoke Detector Wiring handy man88 Electrical 8 11-07-2007 10:05 PM
