-   -   Wiring asmoke detector (http://www.diychatroom.com/f18/wiring-asmoke-detector-61036/)
Mr26t 01-04-2010 07:01 PM
Hey folks can anyone answer this for me? I am putting in a wired /battery smoke alarm but the best place for me to put it I can only get power from a light switch. The switch only has the 2 wires going to it. The top 1 is hot when the switch is off. Any thoughts?
codeone 01-04-2010 07:14 PM
Sounds like you dont have a Grounded conductor(neutral) at the switch. It wont work to power the smoke detector.
You didnt say how many wires are in the switch box and their colors.
Mr26t 01-04-2010 07:34 PM
Sorry I'm new at this chatroom thing. There are only 2 wires in the switch box Also this is an older house and the wires are not colored they are the old cloth covered ones. And if you have not guess I'm not an electrician:(.
codeone 01-04-2010 07:43 PM
Then you do not have a grounded conductor ( neutral ) to make your smoke detector work.
Your line or feed would be up at the light.
Mr26t 01-04-2010 08:03 PM
ALLLL Nuts... It was a good thought while it lasted. Well now I have to figure out plan B. Thanks for your help.
codeone 01-04-2010 08:06 PM
Where is this room 1st or 2nd floor?
Mr26t 01-04-2010 08:14 PM
Its 2nd floor
codeone 01-04-2010 08:17 PM
Are you not able to get in the attic above?
Mr26t 01-04-2010 08:19 PM
There is no attic and to make it worst my walls are plaster.
codeone 01-04-2010 08:58 PM
Why no attic?
You could take the light down lift the box out and fish a wire over to a possible spot. If you messed the plaster up you could ge a medalion that would cover the hole then you mount the light back.
