Wiring Around Screw Terminals - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2008, 03:08 PM   #1
Rewards Points: 81
Wiring around screw terminals
So this is a basic question: Which direction should you "loop" the wire around screw terminals on switches and plugs? Is there a right answer? Is it covered in the code?
The reason I ask is because I have been told both directions for seemingly valid reasons:
Counterclockwise justification: Wrap the wire counterclockwise so that if you try to pull the wire out it will tighten the screw and make it hold better. Wraping the other direction will cause the screw to loosen if the wire gets pulled and release the wire.
Clockwise justification: Wrap the wire clockwise so that when you tighten the screw it acts to tighen the wire in. Wraping the other direction tends to force the wire out as it is tightened.
daxinarian is offline   Reply With Quote
Old 07-14-2008, 03:26 PM   #2
Rewards Points: 266
Clockwise is the correct way.
junkcollector is offline   Reply With Quote
Old 07-14-2008, 03:27 PM   #3
Licensed Pro
Wrap the wire clockwise so the wire is pulled into the screw as you tighten. It is in Article 110 of the NEC
Old 07-14-2008, 04:41 PM   #4
joed's Avatar
Rewards Points: 12,918
Never heard the CCW explanation before. Alway wraps CW.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Wago terminals for residential line-voltage connections BigJimmy Electrical 3 05-22-2008 01:27 PM
Did I screw up wiring this outlet? josquin Electrical 6 06-28-2007 02:39 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
