Wiring A Arc Fault Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2009, 02:26 AM   #1
mikebjohnson
wiring a arc fault circuit breaker
couple questions i have, 1st I have a 12/3 wiring 2 seperate circuits sharing the same neutral, am i able wire one of the circuits to a arc fault breaker?
2nd: i tried wiring the arc fault breaker, i have pre wired neutral going to the neutral buss bar hooked up, and the breaker will turn on, now when i have to hot wire and the neutral wire going to the outlet hooked up the breaker will not turn on, any suggestions on that?
mikebjohnson is offline   Reply With Quote
Old 12-25-2009, 07:21 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
You MUST use a 2-pole AFCI breaker. If one is not available for your panel then you need to go another route, such as a small sub-panel that will accept them.
Why are you installing this AFCI?
Old 12-31-2009, 03:30 PM   #3
mikebjohnson
wiring arc fault breaker
i'm installing the arc fault breaker at my parents because the inspector says it's for code, i can install the breaker with neutral coming off it going wired to the bus bar and it will work, once i touch the load hot or the load neutral it will trip
Old 12-31-2009, 04:04 PM   #4
Is it a 2-pole breaker?
Old 12-31-2009, 04:16 PM   #5
mikebjohnson
it's a single pole breaker, i have one circuit on that and the other circuit wired to a different breaker but sharing the same neutral
Old 12-31-2009, 04:58 PM   #6
As I said previously, this will not work.
Old 12-31-2009, 05:08 PM   #7
As Petey said you need a 2 pole AFCI for 12-3
Or run a dedicated run for the AFCI & use 12-2
You can't share the neutral & split between the AFCI breaker & another
Old 12-31-2009, 05:13 PM   #8
First question, no you can not use an AFCI on a circuit with a shared neutral.
Second question- If this is part of the shared neutral circuit it will not work.
hayewe farm is offline   Reply With Quote
Old 12-31-2009, 05:36 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
What inspector?
Is this a new house, or a remodel job.
If this is a HI, and the house was built to code, tell him to pound sand.
Old 12-31-2009, 05:58 PM   #10
How many times does it have to be stated that 2-pole AFCI breakers DO exist and DO work on (shared neutral) MWBC's!?
Old 12-31-2009, 05:58 PM   #11
I 1000% agree!
This is a favorite catch for HI's in older homes. They make it sound like a "defect" that there are no AFCI's.
Old 01-01-2010, 02:24 PM   #12
" Euro " electrician
frenchelectrican's Avatar
There is two pole AFCI breaker on market btw they are not cheap but they have them.
And OUI! they will work on MWBC like that.
Merci,Marc
Old 04-30-2011, 10:28 PM   #13
Another question relating to the original question
I have a similar question. I ran several 12/3 wires from the panel box to individual junction boxes in the attic. Each bedroom has its own 2 circuit junction box, one for lighting, and one for receptacles.
What are my options to installing arc fault breakers?
Can I use a 2 pole arc fault breaker?
Can I install another junction box next to the panel box have the 12/3 wire go into the junction box and come out with (2) 12/2 wires going into the panel with each 12/2 having it's own arc fault?
Thank you in advance..
zoko is offline   Reply With Quote
Old 04-30-2011, 10:45 PM   #14
Sparky
Rewards Points: 510
This is your only option to get afci protection, if you share the neutral at all.
via 12/3,(hot, hot, neutral) vs 2 runs of 12/2(hot, neutral, hot, neutral)
Techy is offline   Reply With Quote
Old 05-01-2011, 08:30 AM   #15
Lic Elect/Inspector/CPO
What does this circuit feed and what kind of inspector says it is required.
A 2 pole afci will work.
As stated before, if an HI says it is required than he is misinformed.
NJMarine is offline   Reply With Quote
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
Replace a service panel circuit breaker knockout? michigan_homeowner_2008 Electrical 6 05-22-2008 05:01 PM
HELP with Arc Fault Circuit Interruptors! samf Electrical 3 11-24-2006 11:56 AM
Heat Pump compressor trips circuit breaker joejean HVAC 3 08-28-2006 01:15 PM
