Wiring AC Unit Through 20A Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 08:28 PM   #1
whirly's Avatar
Wiring AC unit through 20A Disconnect
I am having some issues wiring my Central Air unit.
Currently there is a red two wire 12G wire running from the AC unit to a 20A Non Fusible, Pull Out Disconnect Switch. Then a Orange Two Wire 10G from the Disconnect to the Breaker Panel. The disconnect has four term screws labeled Load/Line on each. The Wire from the machine has Red to Line and Black to Load on one side, the wire to the panel has a White wire to Line and Black to Load.
Once at the breaker, I have wired the white wire to common/trip and the black to the other side of a 2 Pole 20 Amp Circuit Breaker.
I keep tripping the breaker .... What am i doing wrong.
Is it at the disconnect?
whirly is offline   Reply With Quote
Old 04-26-2009, 08:34 PM   #2
Rewards Points: 2,350
Yes it is at the disconnect. You need to have the wires from the orange cable on the line terminals, and the wires from the red cable on the load terminals.
The way you have it now is a dead short, because each line terminal has a corresponding load terminal. So the black and white from the orange cable are directly connected together through the disconnect.
Old 04-26-2009, 08:38 PM   #3
Electrician
Rewards Points: 792
Your wires comeing from the panel have to go to the line side of the disconnect. The wires going to your unit have to be connected to the load side.
I am assumeing this is 220V. most our, you will have to put both the white and black on the 2 pole breaker.
Make sure you check the nameplate and get the minimun circuit capacity and maxium breaker size. The minumun circuit capacity will give you what size wire you need and the maxium breaker size will give you what the largest breaker you can use. The breaker size will be bigger to compensate for startup.
darren is offline   Reply With Quote
Old 04-26-2009, 09:05 PM   #4
whirly's Avatar
Thats awesome guys, thanks ..
So at the breaker ... was i correct connecting the white to common/trip and the black to the other terminal ..
or does it even matter ?
Old 04-26-2009, 09:19 PM   #5
That is just writing on the breaker case, not an indicator of polarity. For 240 V loads, no, it doesn't matter.
Old 04-26-2009, 09:40 PM   #6
whirly's Avatar
You guys are awesome .... thx!
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
wiring Samsung MH080FXCA4A/MH052FNCA m_driver HVAC 1 07-06-2008 09:44 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
