Wiring For 60 Amp Hot Tub - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 11:03 PM   #1
liscenced electrician
Rewards Points: 538
wiring for 60 amp hot tub
I have a hot tub whose nameplate says 48 amps. The panel is a zynsco. So i would say to put it on a 60 amp breaker with a 4-3 copper cable running over to a 60amp gfci disconnect. This is to be fished in through existing sheetrocked walls. So i can't really do it in conduit. What kind of cable should i be looking for? I havn't seen a 4-3 copper cable
jimmy21 is offline   Reply With Quote
Old 09-28-2010, 02:27 AM   #2
" Euro " electrician
frenchelectrican's Avatar
For the spa/hot tub useage there are few specfic rules you will have to follow and they are pretty strict on this one.
I am not too sure about two pole 60 amp Zinsco breaker can able use with 25mm˛ { #4 AWG } conductors
Are you using the 25mm˛triplex { 4-3 NM cable } or other types ?? and there is one gotcha the NM cable only can use indoor side but once it get outdoor you will have to change to THHN/THWN with four conductor type { Black , Red , White et Green } Sorry no bare conductor allowed on outdoor spa useage this is very specfic in the code.
And I am pretty sure the Zinsco do not make GFCI verison of 60 amp unit at all so you will need a GFCI at the spa disconnection location this is crictal for safety reason.
How far is the load centre to the spa is ???
let us know few details then we will go from there.
Merci,
Marc
Old 09-28-2010, 09:50 AM   #3
Rewards Points: 246
You need a 50 amp circuit not a 60 amp circuit. You could use 6/3 NM (Romex). Make sure its GFCI protected.
Old 10-05-2010, 01:29 PM   #4
Rewards Points: 538
6/3 would sure be a lot cheaper. My overcurrent doesn't need to be sized at 125%?
Old 10-18-2010, 11:36 AM   #5
Rewards Points: 538
ttt
still wondering about this, do i need to size it 125% or not?
Old 10-18-2010, 11:27 PM   #6
No you do not need to oversize this one at all.
Merci.
Marc
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
