Wiring 50a 220 Line - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2008, 08:18 PM   #1
wiring 50a 220 line
I have a welder that I need a 50amp 220 service for. I already have 8/3 armored cable that is plenty long to make the run, however there is no ground wire. Is there no ground in this application? If I do need a ground can I run a green 8awg line with the BX for ground? I included a pic of the plug on the end of the welder.
Thanks for the input!
mgarfield is offline   Reply With Quote
Old 07-27-2008, 08:52 PM   #2
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
yes that plug needs a ground anytime you see a round prong it needs a ground but I am not sure about how to run it since I am only in school yet but i would think that you can't run it with the ac or mc seperatly.
Pudge565 is offline   Reply With Quote
Old 07-27-2008, 10:44 PM   #3
Is your armored cable type AC? If so, you're in luck. The cable armor can be used as the grounding conductor. See the National Armored Cable Manufacturers Association FAQ.
Matsukaze is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 07:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
