Wiring A 40A Cooktop (like A Stove Minus The Oven) - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 04:08 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
In other words, with out any appliance specs, we really cant tell you what wire to pull, but if you have to get it done, then opt for the 8/3 for worse case scenarios...
Old 08-28-2012, 04:18 PM   #17
Rewards Points: 3,130
Check with your local building department. The applicable electrical code where you live will determine what you need to do.
Old 08-28-2012, 04:18 PM   #18
Rewards Points: 164
Originally Posted by stickboy1375 View Post
To do it right? But its a waste of money if his appliance only requires an 8/2...
With that said, if you dont know the required voltage, then spend the extra money on the 8/3 to make sure you have the correct wire.
Here's what was in the install manual for the one I put in, which did have a white wire....
This appliance is manufactured with a white neutral
power supply and a frame connected copper wire.
The frame is grounded by connection of grounding
lead to neutral lead at the termination of the
conduit, if used in USA, in a new branch circuit
installation (1996 NEC), mobile home, recreational
vehicles, where local code do not permit grounding
trough the neutral (white) wire or in Canada,
disconnect the white and green lead from each
other and use ground lead to ground unit in
accordance with local codes, connect neutral lead
to branch circuit-neutral conductor in usual manner
see Figure 5. If your appliance is to be connected
to a 3 wire grounded junction box (US only),
where local code permit connecting the appliance grounding
conductor to the neutral (white) see
Figure 4.
ryan50hrl is offline   Reply With Quote
Old 08-28-2012, 04:19 PM   #19
Rewards Points: 164
Works for me.....
:thum bup:
The Following User Says Thank You to ryan50hrl For This Useful Post:
stickboy1375 (08-28-2012)
Tags
cooktop
stove top and drop in oven Linda J Appliances 1 05-26-2012 03:40 PM
Freestanding range to cooktop + oven combo. Lots of data (kw, wiring, etc) made2last Electrical 12 04-07-2012 12:19 AM
Direct Wiring a stove javajunkie Electrical 9 11-19-2010 06:07 AM
50A 220V breaker split to oven & cooktop seefut Electrical 2 05-04-2010 08:37 PM
Stove wiring? OSt8Pokes Electrical 2 03-01-2005 05:53 AM
