Wiring A 40A Cooktop (like A Stove Minus The Oven) - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 02:08 PM   #1
Rewards Points: 1,062
Question
wiring a 40A cooktop (like a stove minus the oven)
the instruction manual i got from the whirlpool site was kindof ambiguous between 3 and 4 wire cable. it included instruction for both. i understand i can't go wrong with 8/3 cable but 8/2 would certainly be cheaper. so my question is:
do most cooktops require 240/120 and two hots, meaning 8/3 cable or is 8/2 OK?
reference: http://www.whirlpoolwaterheaters.com...ds/6510306.pdf
Old 08-28-2012, 02:13 PM   #2
Rewards Points: 164
Both require two hot, it's whether the neutral
and ground are bonded together or not. You should run 4 conductors total to meet current code
ryan50hrl is offline   Reply With Quote
The Following User Says Thank You to ryan50hrl For This Useful Post:
amakarevic (08-28-2012)
Old 08-28-2012, 02:19 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What are you talking about? The appliance is either 240v, or 240/120v... (The slash rating is what determines you need a neutral)
Unless the appliance needs a neutral connection, (highly doubtful in a cooktop) then a 2 conductor plus ground is all that is required.
Old 08-28-2012, 02:39 PM   #4
Rewards Points: 164
How is a cooktop different than an electric range that can have 3 or 4 wire hookups
I ask cause the last cooktop I put in had 4 wires.
Old 08-28-2012, 02:42 PM   #5
E2 Electrician
I question your comment about bonding the ground and neutral.
Old 08-28-2012, 02:47 PM   #6
Rewards Points: 164
Recalling from memory, aren't the neutral and ground on 3 wire connection for this bound together?
Old 08-28-2012, 02:48 PM   #7
E2 Electrician
Which is against code on a new installation.
Old 08-28-2012, 02:50 PM   #8
Rewards Points: 164
Which is why I said to run 4 conductors
Old 08-28-2012, 02:59 PM   #9
E2 Electrician
So that was a waste of conversation. The whole point of the OP's thread was weather he could run 2 conductors or 3, i've never seen a 4 wire cooktop. so if you have a link for the one you did, it would be cool...
Old 08-28-2012, 04:49 PM   #10
Dude, check the URL i submitted in the original post. It shows exhibits with both 3 and 4 wires
Old 08-28-2012, 04:53 PM   #11
Let's form the question this way:
is it 8/2 or 8/3 cable that i need?
Old 08-28-2012, 04:57 PM   #12
Master Electrician
Rewards Points: 3,698
Dude, the url is for water heaters.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 08-28-2012, 05:01 PM   #13
Oh sorry, i was looking at different PDFs
here we go
http://www.whirlpool.com/digitalasse...ruction_EN.pdf
Old 08-28-2012, 05:03 PM   #14
Rewards Points: 164
8/3 is what i'd use to do it right.
Old 08-28-2012, 05:06 PM   #15
E2 Electrician
To do it right? But its a waste of money if his appliance only requires an 8/2...
With that said, if you dont know the required voltage, then spend the extra money on the 8/3 to make sure you have the correct wire.
Tags
cooktop
stove top and drop in oven Linda J Appliances 1 05-26-2012 04:40 PM
Freestanding range to cooktop + oven combo. Lots of data (kw, wiring, etc) made2last Electrical 12 04-07-2012 01:19 AM
Direct Wiring a stove javajunkie Electrical 9 11-19-2010 07:07 AM
50A 220V breaker split to oven & cooktop seefut Electrical 2 05-04-2010 09:37 PM
Stove wiring? OSt8Pokes Electrical 2 03-01-2005 06:53 AM
