I'm trying to install illuminated Leviton Decora switches to control the lights in my Basement that are switched from 3 locations. I have (2) 3-way switches and (1) 4-way switch in the middle.
I am having trouble wiring in the three switches so I can operate the lights from all locations AND get ALL the switches to illuminate when the lights are turned off and hope someone can clarify the correct installation sequence for me.
Here is the current switch and wiring arrangement:
SWITCH #1 (3-way) has a 3 conductor (B/W/R + grnd) wire running to SWITCH #2, which is a 4-way switch.
SWITCH #2 also has a 3 conductor (B/W/R + grnd) wire running to SWITCH #3, which is a 3-way switch.
SWITCH #3 has the 3 conductor (B/W/R + grnd) wire from SWITCH #2, a 2 conductor (B/W + grnd) wire from the elec panel AND a 2 conductor (B/W + grnd) wire to the Basement Lights.
1. At SWITCH #1 (3-way), do I connect the White or Black conductor to the BLACK terminal labeled "COMMON"? I'm assuming that the Red conductor is my "Traveler" conductor that gets connected to one of the non-common Brass terminals.
2. At SWITCH #2 (4-way), there are 2 terminals on each side of the switch. The switch is labeled "IN" on one side vertically and "OUT" on the other vertically.
· Do I connect the Red and Black "Traveler" conductors from SWITCH #1 to the same side of the 4-way switch?
· Do I connect the "Traveler" conductors from Switch #1 to the "IN" or "OUT" side of the 4-way switch?
· If I want to eliminate this switch, can I wire the Red and Black conductors from the wires running from Switch #1 & Switch #3 to Switch #2 by connecting Black / Black and Red / Red together?
3. At SWITCH #3 I have 4 conductors to wire to 3 terminals. The White conductors on all wires at this location are connected together.
· What terminals on the switch do I wire the "Traveler" conductors from Switch #2 to?
· What terminal do I connect the Black conductor to the lights to?
· What terminal do I wire the "Black" assumed "HOT" wire from the elec panel to?
Thanks for ANY help clarifying this mess.
