Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 09:13 AM   #1
Wiring
Had a question about wiring a dustcollector for my shop.
I have run a 12/2 wire to this and the motor on the dust collector is a
115/230. Can i use a double 20 amp breaking for a 220 amp circuit ?
the motor is set on the 220 phase side. Any help would be great.
Travis L
Travis L is offline   Reply With Quote
Old 02-03-2009, 09:55 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes as long as the 20 amp double pole breaker and wire is sufficient for the dust collector load requirements. Do not mistake double pole breakers for the single pole tandem type.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-03-2009, 01:13 PM   #3
The breaker that I have is a ge 20 amp with bar connecting the two breakers together. I did this a while back on my well pump and used the black and white as power leads and the copper as ground.
Is there any other ideas that would work better. Thanks for your help
Old 02-03-2009, 05:53 PM   #4
Stubbie, you have me mystified! For my edification, (smile) would you explain what a tandem breaker is? This is new to me!
Old 02-03-2009, 06:04 PM   #5
Remodeling Contractor
Tandem breakers are two single pole breakers that fit into on bus slot. The 2P20 will be fine for the dust collector. Be sure it is wired for 220V, open and verify. Also be sure to run a grounding wire through all the supply hoses to prevent static buildup. The charge can cause a fire in your shop.
Old 02-03-2009, 06:09 PM   #6
Tandem breaker, same width as a normal single pole breaker
Old 02-03-2009, 06:19 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Wildie
Sorry if I wasn't clear I thought by saying single pole tandem type it would be non-confusing. I see the other guys have clarified.
Stubbie
Old 02-03-2009, 06:21 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
No... you have the right breaker and understand correctly
Stubbie
Old 02-03-2009, 07:23 PM   #9
Aww! A light goes on! This is what I thought was a split breaker! I'm thinking that a bicycle built for two is called a tandem bicycle and I'm thinking of one pole going through two breaker elements! Duhhh!
Old 02-03-2009, 07:34 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Wildie
It happens all the time depending on where your from they might be called split, tandem ,twin, duplex. I wouldn't beat myself up too much over it.
Stubbie
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 03:06 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
