Old 11-04-2012, 03:08 PM   #1
Question
Wiring 3 way switch with multiple lights
I'm doing a remodel trying to wire can lights. I want to wire power to switch then multiple lights and finish at a second switch. I've run 14-2 to first switch, 14-3 between lights and to second switch. Q - How do I wire the lights so they are in parrallel and not series? Thanks!
Darrenp is offline   Reply With Quote
Old 11-04-2012, 04:14 PM   #2
A "Handy Husband"
rjniles's Avatar
You can't, you do not have enough wires between the switches. Run the 3 wire between the switches and run 2 wire from one of the switches to the first light and on to the rest.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 11-04-2012, 04:15 PM   #3
Electrical Contractor
You can't. you need one more wire.
Are the cei;ings still open?
Run a 3 wire cable from switch #1 to switch #2, then a 2 wire cable from #2 to the first light, then to each light after that.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-04-2012, 04:26 PM   #4
http://www.buildmyowncabin.com/electrical/img14.gif
How Wire Multiple Lights 4 Way Switch NaJoe Electrical 4 07-04-2012 08:41 AM
Multiple lights with one switch DIY Mark Electrical 1 12-03-2011 12:15 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Basement lighting circuit - multiple lights and switches, end of circuit cmyk Electrical 2 03-03-2011 03:39 PM
