Old 02-02-2013, 05:57 PM   #1
wiring 3 way switch
i am wiring 3 way switch for 10 recessed lighting.
14/2 from breaker to switch 1, 12/3 from switch 1 to switch 2.
14/2 from switch 1 to light 1
14/2 from switch 2 to light 1
light 1 in series with 14/2 to light 2, then 3, then 4, 5, 6,7,8,9, end with 10 (last stop for 14/2).
is this correct???
thanks
i'm using 12/3 instead of 14/3 because my dad has a bunch thats only reason.
jpelizza is offline   Reply With Quote
Old 02-02-2013, 06:08 PM   #2
MarginallyQualified
wiring 3 way switch
Originally Posted by jpelizza View Post
i'm (planning on) using 12/3 instead of 14/3 because my dad has a bunch that's only reason. ... is this correct???
No. Don't use different gauge wires on the same circuit.
3way switching:
14/2 from source to switch 1, then
14/3 from switch 1 to switch 2, then
14/2 from switch 2 to the light(s) (to light to light to light)
10 is a lot of lights. How many watts will each draw?
TarheelTerp is online now   Reply With Quote
Old 02-02-2013, 07:55 PM   #3
wiring 3 way switch
Ok great, thanks for reply.
I also running three way switch for ceiling fan.
14/2 from switch 2 to fan.
That right??
Fan will have up lighting down lighting and a fan.
Kansas is offline   Reply With Quote
Old 02-02-2013, 07:57 PM   #4
wiring 3 way switch
3way switching:
I'm putting flu recent lights so 14w each. Room is big 16x25 and I like light lol
Old 02-02-2013, 08:40 PM   #5
Licensed electrician
wiring 3 way switch
That right??
This will only allow you to control both at the same time unless pull chains are also used.
Old 02-02-2013, 09:49 PM   #6
wiring 3 way switch
well im assuming the fan will have a remote and also the option of the inwall switch that has light dimmer, fan, light button. so if that is what i get can i still use the 14/2 or do i need 14/3 to the fan from the switch??
thanks
Old 02-02-2013, 09:51 PM   #7
wiring 3 way switch
I would run a 14-3 to the fan. It gives you more options down the road.
Old 02-02-2013, 09:52 PM   #8
wiring 3 way switch
Thanks that's what I was thinking but wasn't sure
Old 02-03-2013, 06:59 AM   #9
wiring 3 way switch
That right??
here is a diagram I had saved with two three-way switches where one controls a fan motor and the other controls the down light canopy on the fan. You could add another 3-way for the up canopy light.
hammerlane is offline   Reply With Quote
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
