-   -   wiring 3 way switch (http://www.diychatroom.com/f18/wiring-3-way-switch-170847/)
jpelizza 02-02-2013 04:57 PM
wiring 3 way switch
i am wiring 3 way switch for 10 recessed lighting.
14/2 from breaker to switch 1, 12/3 from switch 1 to switch 2.
14/2 from switch 1 to light 1
14/2 from switch 2 to light 1
light 1 in series with 14/2 to light 2, then 3, then 4, 5, 6,7,8,9, end with 10 (last stop for 14/2).
is this correct???
thanks
i'm using 12/3 instead of 14/3 because my dad has a bunch thats only reason.
TarheelTerp 02-02-2013 05:08 PM
Originally Posted by jpelizza (Post 1108072)
i'm (planning on) using 12/3 instead of 14/3 because my dad has a bunch that's only reason. ... is this correct???
No. Don't use different gauge wires on the same circuit.
3way switching:
14/2 from source to switch 1, then
14/3 from switch 1 to switch 2, then
14/2 from switch 2 to the light(s) (to light to light to light)
10 is a lot of lights. How many watts will each draw?
Kansas 02-02-2013 06:55 PM
Ok great, thanks for reply.
I also running three way switch for ceiling fan.
14/2 from switch 2 to fan.
That right??
Fan will have up lighting down lighting and a fan.
Kansas 02-02-2013 06:57 PM
3way switching:
I'm putting flu recent lights so 14w each. Room is big 16x25 and I like light lol
Jim Port 02-02-2013 07:40 PM
That right??
This will only allow you to control both at the same time unless pull chains are also used.
jpelizza 02-02-2013 08:49 PM
well im assuming the fan will have a remote and also the option of the inwall switch that has light dimmer, fan, light button. so if that is what i get can i still use the 14/2 or do i need 14/3 to the fan from the switch??
thanks
Jim Port 02-02-2013 08:51 PM
I would run a 14-3 to the fan. It gives you more options down the road.
Kansas 02-02-2013 08:52 PM
Thanks that's what I was thinking but wasn't sure
hammerlane 02-03-2013 05:59 AM
1 Attachment(s)
That right??
here is a diagram I had saved with two three-way switches where one controls a fan motor and the other controls the down light canopy on the fan. You could add another 3-way for the up canopy light.
