Wiring 3 Switches With One Home Run. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 10:28 AM   #1
Rewards Points: 154
Wiring 3 switches with one home run.
I am wiring my theater room lights and not sure what the easiest way to do this would be. Should I run it into the 3 gang box and pig tail there?
OR
The wall the switches are on is a divider wall between the theater and HVAC room (unfinished wall). I could put a junction box there and run my home run into it and then run 3 separate wires to the switches so my switch box wouldn't be so full.
What would be the best way?
Thanks, Abs777
Abs777 is offline   Reply With Quote
Old 10-19-2010, 11:26 AM   #2
I think I would pigtail in the switch box. If you use a separate junction box, you may make wiring the blacks easier, but:
- you now have a potential need to wire six white wires together. You could join each white supply with each white load, but that would defeat the purpose of having the junction box
- you now have an ungly access panel in your wall
I don't believe it much of a problem doing a pigtail in the switch box.
oberkc is offline   Reply With Quote
Old 10-19-2010, 01:13 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 416
To the switchbox James!!!!!!
jbfan is online now   Reply With Quote
Home Reno Wiring Problem Henry H Electrical 17 05-21-2010 08:24 PM
Home wiring problem CAD Electrical 8 10-17-2009 02:26 PM
mobile home light switches mjadec01 Electrical 15 10-15-2009 08:57 PM
Wiring Ethernet and Speakers in my home question seroth Electrical 10 01-18-2008 03:19 PM
