Wiring 3 Post Lights.... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 11:00 AM   #1
wiring 3 post lights....
ok i have 3 post lights on one switch (dimmer)....no lights were there so cant just copy......first light has black/white/orange wires.....same for second black/white/orange.....and third has black/white/green which is simple and obvious.....the first 2 have no green/ground....how would i wire these?? do the orange go with black??? please advise
ibe555666 is offline   Reply With Quote
Old 10-19-2012, 11:40 AM   #2
Rewards Points: 150
These are all new fixtures? Did they come with instructions and/or a wiring diagram?
What's the brand and model number? Probably can find data on them online.
Dave632 is offline   Reply With Quote
Old 10-19-2012, 11:46 AM   #3
all new fixtures
standard post lamps....black/white/bare ground.....my question is the existing wiring at the posts.....as stated in original post 2 are black/white/orange.... last is black/white/green which is obvious....need to know thoughts on wiring each lamp excpet the last i guess
Old 10-19-2012, 12:16 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 150
You need to find out where that orange wire comes from.
Have you opened the switch to see if it is there?
jbfan is online now   Reply With Quote
Old 10-19-2012, 12:39 PM   #5
Rewards Points: 2,512
......first light has black/white/orange wires.....same for second black/white/orange.....and third has black/white/green dplease advise
How are we suppose to know where the orange insulated wire terminates? Stop getting hung up on the color of the wire insulation and determine where this orange colored wire 's other end is at.
I think a good starting point as jbfan suggested is the switch location? Maybe . Possibly?
hammerlane is offline   Reply With Quote
Old 10-19-2012, 12:53 PM   #6
Rewards Points: 150
Is there a single black/white/orange cable coming to the top of the post, or a pair of them? Does the B/W/O cable also contain a bare ground wire?
If it's just one cable, there must be a junction box at the base of the post, right?
Old 10-19-2012, 12:55 PM   #7
will look
will look at switch see what i have there.....isnt it odd to not have a ground in 2 of the posts??? these are preexisting obviously and all wiring is underground so it makes it a little difficult...
Old 10-19-2012, 12:58 PM   #8
2 post have separate wires...bl/wh/orange with no green or bare....one has bl/wh/green.....all wires separate in pvc underground/concrete...they all run off same circuit as the posts are around a pool to light it.
Adding wiring for under cabinet lights from a three way switch Dale8 Electrical 0 10-07-2012 03:50 PM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Wiring 6 Recessed Lights in Kitchen shawjd1 Electrical 3 01-27-2011 08:53 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 02:10 PM
Wiring post outlet and lamp for light post Gordon Electrical 3 09-22-2008 03:39 PM
