Wiring 240volt Baseboard Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 11:46 AM   #1
Hello,
I have 3 phase electric.
I hooked up a 240 volt baseboard heater to the two low sides. 110+110
My question is, can I hook it up to one low side and one high side?
Thanks!
ideal7733jeff is offline   Reply With Quote
Old 12-06-2010, 11:57 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Do you have a high leg delta or a wye 3 phase?
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
ideal7733jeff (12-06-2010)
Old 12-06-2010, 12:11 PM   #3
Not sure.....Every third leg is 240 volt
Old 12-06-2010, 12:32 PM   #4
After looking at the transformers I believe it's Delta
Old 12-06-2010, 08:57 PM   #5
" Euro " electrician
frenchelectrican's Avatar
If this is your home then more likey you have 4 wire delta system and there is one gotcha is wild leg from phase B to netural it will show up 208 volts so try to advoid it if you have line to netural load.
For your straight 240 volt electric heater it will not be a issue it will work on any phase { A-B or B-C or C-A }
but only gotcha is that if you use on AB or BC you will need straight 240 volt rated breakers { the AC is not a issue due you will have legit netural there }
And all the 240 volt load will need two pole breakers you can NOT use single pole breaker on this set up.
However if this is in commercal building then all bet is off !
Merci.
Marc
220v vs 110v Baseboard Heater?? Master Brian Electrical 8 11-20-2010 12:13 AM
thermostat wiring for electric heater Captflx HVAC 3 03-05-2010 09:48 PM
Electric Wiring for Pool Heater (heat pump) tazmajazz Electrical 7 10-21-2009 09:49 PM
Baseboard heater under window jhubert Electrical 1 10-07-2009 11:59 PM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 01:13 AM
