Old 05-17-2009, 01:14 AM   #1
777
Default wiring a 240V baseboard heater
Hoping for some help here:
I am wanting to wire a 240V baseboard heater in our basement. Run a line directly from my panel in the garage to the basement.
I purchased a double pole t-stat today..instructions are in spanish and don't have a clue
Also the 240v breaker I picked up is the space equal of 4 of those blue switches in the pics below.
OK
I need to install a new breaker in my panel that seems it wont fit a 240V breaker. See the photos below However, there is a breaker with green tape on it ironically already labelled baseboard heaters. if you zoom in on the pics you can get a good look at it. This is not in use right now based in the pics could i tap into this breaker with the appropriate wire? It seems there is only 120 v wire on this double switch. (White and black wire)
My understanding is i run the wire from the panel to the t-stat then to the baseboard heater. Any tips would be greatly appreciated about wiring this up correctly. What colored wires go from the panel to the t-stat and then to the heater?
Also im very confused about a new breaker in the panel itself how it would fit or if i could use the existing one with the green tape on it.
photos:
http://img199.imageshack.us/my.php?image=imgp1001.jpg
http://img194.imageshack.us/img194/2909/imgp1054.jpg
http://img190.imageshack.us/img190/9209/imgp1055d.jpg
http://img194.imageshack.us/img194/2264/imgp1057.jpg
http://img198.imageshack.us/img198/4392/imgp1053.jpg
777 is offline   Reply With Quote
Old 05-17-2009, 01:48 AM   #2
Idiot Emeritus
The breaker with the green tape on it is indeed 240 volt, provided it has a handle tie, like the other 240 volt breakers. The handle tie is the little silver thing between the two handles, like the green (30 amp) and gray (40 amp) breakers.
It's 15 amp, so the minimum wire size is #14.
Using black or red tape (a black or red marking pen will do as well), re-identify the white wire as black or red. Most of us prefer red. Both ends.
Rob
micromind is offline   Reply With Quote
Old 05-17-2009, 02:36 AM   #3
777
Yes it does have a handle tie. Exactly the same as the breaker above it in the panel. See the picture below
Also, I purchased a breaker the one in the picture below. I think the people at home depot completely steered me in the wrong direction.
Also, the wire they said I needed was the red/black 12 see pic.
Frustrated with that store.
Anyways. The previously mentioned breaker is a 240V as you mentioned. It already has #14 wire I believe wired to two locations. It is not in use therfore it was taped "off" This would really simply my install process if i just taped into the pre existing wire which terminates in a box in the garage just on the other side of the wall where i want to place the heater in the basement actually...could i be so lucky?
Here are some more pics for clarity purposes:
The breaker Home Depot sold me after i told them the specs of my panel. I don't think it is the right one and I now think it is not necessary:
http://img33.imageshack.us/img33/3042/imgp1059.jpg
The breaker that I can use for the 240V (green tape removed):
http://img39.imageshack.us/img39/1867/imgp1064.jpg
The wire Home depot sold me but its not needed now..that was $40 bucks:
http://img195.imageshack.us/img195/291/wire.gif
The wire that's already installed. I believe it's #14:
http://img33.imageshack.us/img33/1108/imgp1065.jpg
OK so if all is already wired correctly and i have a black and white at my wall where do i go from there. It was mentioned to color the white wire "red".
Can i wire the base board heater first then run it up to the t-stat or is it recommended to run to the t-stat first then the baseboard heater.
What wire color would I connect to what - the instructions are dreadful. Here is a pic of my t stat and the baseboard heater just has 2 black wires.:
Thank you for the direction/help
Andrew
Old 05-17-2009, 03:23 AM   #4
" Euro " electrician
One thing I relized that you are in Canada area this should be almost the parallel with USA side.,
If you going to use the exsting 14 gauge conductors that pair one should be remarked to red or bleu { that my refernce but it your choice anyway } that will have max of 15 amp breaker there.
Now for the thermost can you run me the manufacter name and model numbers to make sure I can able find it one way or other and if that the case I will provide the instruction in both engish and french.
I am pretty sure that is legit double pole thermostat that one you show us the photo that will be little tricky unless you follow the instruction excatally as we will tell you.
If you tell us the model number and I am pretty sure both black is for line side while red is for load side however it can be reversed as well but need the model number to confirm excat details.
Merci,Marc
Old 05-17-2009, 03:33 AM   #5
777
Bonjour, Merci Beaucoup
Yes I am in Canada but English Speaking Canada LOL British Columbia
I purchased a Dimplex Double Pole Line voltage Thermostat TD322W
The top of the t -stat has a black and red and the right side of the back has a red above a black. I dont know if that is visible in the pictures?
The baseboard heater has 2 black wires and a grounding screw of course. One of the black wires seems to be connected to the heating element.
Should the two black wires from the T stat run to the baseboard heater and the two red wires connect to the panel. In my case one is black and one is white ( but coloured red) Am I on the right track?
thanks for your help
Andrew
Old 05-17-2009, 03:54 AM   #6
Oui {Yes } it is clear shot and I will dig up that manufacter spec real quick in a minute.
Oui ., Of course that is the correct way from the factory one conductor from the heating element is correct and second one go to the safety thermostat { some case it will be a safety fuse as well } I will explain with the hook up in lower comment part so just read on along the way.,,
Are the two black wires from the T stat running to the baseboard heater and the two red wires connected to the panel. In my case one is black and one is white ( but coloured red) Am I on the right track?
Andrew
What I will do is combine multi question into one shot here .,
Now for your NMD cable from the breaker to the thermostat now here please pay attetion to this instruction carefull otherwise if done wrong it may destory the thermostat !
{ I will add two links due my multi langunge here}
The red thermostat conductors are line side while black conductor is load side and I will put a link so you can read in PDF format
http://partner.dimplex.com/files/dom...00rev00(1).pdf { EN}
http://partner.dimplex.com/files/dom...rev00FR(1).pdf {FR}
After you read the instuction on the pdf it will show the picture how it hook up correct and once you get that part done then go to the baseboard heater either red or black conductor will hook up either black conductor and use the proper marttee { wire nut }
And it should work perfect as long you follow the instruction carefully with it.
If you have more question just holler one of us will help ya
Merci,Marc
Old 05-17-2009, 11:04 AM   #7
777
Thats great thank you kindly. I will wire it up today and let you know how things go.
from the instructions you have provided ( double pole t stat - second part of the instructions) It looks like i was on the right track in my thinking. The two black wires from the t -stat run to the baseboard heater. However, because I have #14 wire the instructions refer to 2 red lines connected to the power supply/panel. In my case my two red lines will be one black and one white (painted red). Does it matter which is connected to which or are both technically the same in this situation.
I just want to double check this. Sorry for my ignorance if this seems so simple but it is something I don't work with
regards,
Andrew
Old 05-17-2009, 11:15 AM   #8
I must be missing something, I don't see any mention of the wattage of the baseboard heater. Are you sure 15 amp service will be enough?
hayewe farm is offline   Reply With Quote
Old 05-17-2009, 12:17 PM   #9
777
Hmmmmm
It is one 2000W 240V baseboard heater. Will i have issues?
Old 05-17-2009, 12:41 PM   #10
Shouldn't be a problem with that size , that's only about 8.3 amps.
Old 05-17-2009, 12:47 PM   #11
777
Ah Success!!! Everything wired up nicely and We have heat just in time for summer LOL
I really appreciate everyones comments
A bit of a smell to it when i first turned it on...not a frying circuit smell but new heater smell. Im sure that will go away with time
thanks again,
Andrew
More On This Topic
If you want to install an outdoor fan, you should wire a nearby switch so you can control it easily. There are various types of switches that you can use, but what matters most is that you are using components that are safe for outdoor use. Read More »
Basic Hot Tub Wiring
Basic Hot Tub Wiring by Expert Village
OK, here we're going to talk about the different wiring requirements for spas. Many spas, most common will be a two-forty volt, fifty amp dedicated circuit, which means that is it on its own breaker, it is a GFCI breaker which is for your safety and also... Read More »
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
Hi! I'm Drew Finn and I am here for expertvillage.com. I am a professional home inspector and I am going to show you how to install a ceiling fan today. The thing that you want to make sure of is you have a very firm steady ladder. Okay, what we are... Read More »
Pull the dash piece. Behind here you have the crossover for the stereo system. Let's move that out of the way. You have your air conditioning components. Here is your heater core. Access in the heater core wiring is right here in this harness. But... Read More »
240V baseboard heater - 12/2 or 10/2 ? pmoe Electrical 24 12-20-2008 12:40 PM
Wiring a 220 Baseboard Heater joedadog Electrical 8 10-06-2008 08:17 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 05:32 AM
Wiring tankless water heater TheBossQ Electrical 4 07-11-2008 02:05 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 06:01 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
