Wiring 240 V Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 09:56 PM   #1
wiring 240 V switch
I am installing a 240 V switch for a 1 hp motor. I see there are two gold screws on the top and two bronze ones on the bottom. Do I attach the wires going in to the two top screws or the two screws on the left?
Thank you
erlindbl is offline   Reply With Quote
Old 02-25-2009, 10:27 PM   #2
Line on one set (top) load on the other (bottom).
If you do it wrong, you will know as soon as you turn the switch on
The instructions should be on the box.
220/221 is offline   Reply With Quote
Old 02-26-2009, 12:32 AM   #3
You would have thought so. I looked over every inch of the box and on the switch itself. No instructions inside either. It is a Levitron.....
Thank you
Old 02-26-2009, 01:27 PM   #4
Rewards Points: 81
Try checking continuity between the terminals...
daxinarian is offline   Reply With Quote
Old 02-26-2009, 01:41 PM   #5
Rewards Points: 1,910
Wouldn't that take the fun out?
Old 02-26-2009, 02:57 PM   #6
Electrician
Thank you
Make sure the switch actually says ON/OFF.
chris75 is offline   Reply With Quote
Old 02-27-2009, 10:37 AM   #7
Rewards Points: 204
Make sure you get a good heavy duty 20 amp two pole switch. The motor will draw about 8 amps running, but it will draw much higher current when starting. This is not the time to skimp on the switch.
Old 02-27-2009, 11:55 AM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If your using a general purpose snap switch for 2hp 300 volts or less motors the motor flc cannot be greater than 80% of the switch rating for the switch to serve as a disconnect. Table FLC is around 8 amps as J.V. noted. So any 15 amp double pole or greater will suffice for the disconnect.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-28-2009, 01:36 AM   #9
I got the switch from the electrical supply house. It is a 1 hp motor and they said the switch was rated up to a 2hp motor. Since the switch is in my garage 250 feet away from the well, I have a separate pull out disconnect installed there.
Thanks for the input.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 09:58 AM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
