Wiring A 230V Air Compressor - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 04:09 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I love it when the OP never comes back.
Old 04-04-2013, 09:41 PM   #17
joed's Avatar
Rewards Points: 12,430
It depends on what you want it to do.
1. OK
2. You will be able to turn it on from either place. But will need to be off at both locations for it to be off. That is if you turn it on in the garage you can turn it off in the garage but not from the basement. If you turn it on at both switches you have to turn it off at both switches or it won't be off.
3. Best solution(maybe not the cheapest) but you will be able to turn on or off from either location and not care which location turned it on.
May not come back but posting the same question on other sites.
http://handymanwire.com/ubbthreads/u...sor#Post750399
Old 04-05-2013, 05:32 AM   #18
Rewards Points: 321
He came back (#10 and #11). I suspect he got his answer, as several good opinions were presented.
al_smelter is offline   Reply With Quote
Old 04-05-2013, 08:08 AM   #19
TTW
TTW's Avatar
#3 all day long...
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 04-06-2013, 05:30 PM   #20
Thanks for all the good feedback. Based on your responses, I've decided to go with option #3, the contactor.
- The distance from the service panel to the compressor is about 15 ft.
- The distance from the compressor to the garage switch is about 50 ft.
- I assume the contactor will be placed next to the compressor in order to minimize the amount of 10g wire.
- The basement is unfinished so it won't be a hassle to run the wires.
- My panel has plenty of room for a 30 amp breaker.
What do you think would be a reasonable price for this job?
Thanks again.
jjscott is offline   Reply With Quote
Old 04-06-2013, 05:54 PM   #21
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks again.
To make this job easier, I would just install a pico wireless switch and remote , the switch would energize the coil wirelessly... save you some time and labor of running a remote wired switch somewhere....
The Following User Says Thank You to stickboy1375 For This Useful Post:
mpoulton (04-06-2013)
Old 04-06-2013, 06:48 PM   #22
Semi-Pro Electro-Geek
Rewards Points: 2,922
Wireless would be easier. If you go wired, I'd use a 24V contactor and run bell wire to the switches instead of 120V controls. You could use three-way switches, or you could use a pair of pushbuttons at each location, one for start and the other for stop. I think the total parts cost will be somewhere around $200-300, and about a day of labor.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 04-07-2013, 07:04 AM   #23
Thanks for the wireless suggestions, but I'd rather stay with a wired solution. What do you think would be a reasonable cost for a wired solution?
Old 04-07-2013, 12:42 PM   #24
Probably $500-$1000, mostly labor. You could do it yourself for a couple hundred.
Old 04-07-2013, 12:44 PM   #25
E2 Electrician
why?.......
Old 04-07-2013, 03:00 PM   #26
Because I believe it would be more expensive than running a low voltage wire. The wireless switch is cheap enough, but the receiver is a little too pricey for me.
Old 04-07-2013, 03:01 PM   #27
E2 Electrician
you can do a wireless setup for 60 dollars... you cant make up your labor under that price... but do what you feel is easier for your situation.
Old 04-07-2013, 03:06 PM   #28
What's the part number for the pico wireless receiver? I was poking around on their site after reading your first post and I thought is was $100.
Old 04-07-2013, 03:09 PM   #29
E2 Electrician
http://www.amazon.com/Lutron-MRF2-6A...ds=lutron+mrf2
I need help wiring my thermostat. batalbj1 HVAC 3 03-28-2013 10:30 PM
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 08:04 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
HVAC compressor contacts wiring???? mflores00 HVAC 1 05-28-2010 09:50 PM
