Wiring A 220v Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 12:51 PM   #1
Wiring a 220v outlet
Ok so I'm installing a new 220v outlet in my garage running the wires through pre existing conduit. It's a NEMA 6-50 style (two hots and a ground) and I want to limit the number of wires I will be running through the conduit. My question is can I connect the ground wire from the plug, and screw it to the plug enclosure? Or is it necessary to wire it through the conduit and connect it to the panel? I do have another 220 wiring for the AC and there are only two wires going up the conduit so I'm assuming the ground for that is connected to the enclosure? Let me know.
Thank you!
Econdron is offline   Reply With Quote
Old 10-22-2012, 01:09 PM   #2
Julius793's Avatar
What kind of conduit? And when you say plug do you mean receptacle?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 10-22-2012, 01:12 PM   #3
Sorry, yes I meant the receptacle. It's 1/2" conduit, and I've been told by several electricians that up to 6 #10 THHN wires can be crammed into 1/2" but there are already a couple #14 wires in there. And just for ease of pulling the wires through I would way rather only pull two through than three.
Old 10-22-2012, 01:13 PM   #4
And it's EMT rigid conduit.
Old 10-22-2012, 02:33 PM   #5
Julius793's Avatar
Well then you don't need a ground wire the conduit serves as a ground
Old 10-22-2012, 04:08 PM   #6
Oso954's Avatar
Rewards Points: 420
Why are you talking about #10 wires when you are also discussing a 50 amp receptacle ?
Also, is this an attached or detached garage ?
Oso954 is offline   Reply With Quote
Old 10-22-2012, 04:12 PM   #7
Licensed electrician
Rewards Points: 1,018
You are going to need a larger conduit for the #6s.
Old 10-22-2012, 04:48 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
EMT and rigid conduit are 2 different things.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
brric (10-25-2012)
Old 10-22-2012, 05:39 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
If it's THHN conductors in conduit you can use #8cu.
Old 10-25-2012, 05:35 PM   #10
The outlet is for up to 50 amps. I'm using a 30 amp breaker. And sorry, I meant just EMT.
Old 10-25-2012, 06:56 PM   #11
Oso954's Avatar
Rewards Points: 420
Putting a 50 amp receptacle on a 30 amp circuit is a bad idea most of the time. Someone might plug a 50 amp load in it.
Anything you buy that works on 30 amps may come with a 30 amp plug.
Then you will have to change it to a 50 amp plug, before you plug it into this circuit.
If you do have a good reason to use the 6-50r, I would label it "30 amp service".
Old 10-25-2012, 07:00 PM   #12
What makes you think this is unsafe or a "bad idea"?
A 50A receptacle on a 30 circuit is legal and safe. If the load is too big the breaker will trip. Simple as that.
Also, some loads will come with a 50A plug. My 180A mig welder comes with a 50A plug and is no where near pulling 50A.
Old 10-26-2012, 09:12 AM   #13
Yeah I'm using it for my welder too. Hobart technical support was the one that told me to use the 6-50r receptacle with a 30amp breaker.
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 07:37 AM
Outlet Wiring Help Needed djcirello Electrical 2 02-03-2012 02:09 PM
Wiring Switched Outlet matt151617 Electrical 15 07-03-2011 02:16 PM
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 11:54 AM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 09:10 PM
