Wiring 220v Baseboard Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 06:44 PM   #1
Rewards Points: 27
wiring 220v baseboard heater
Can I run 2 additional 12 gauge wires in existing EMT for a baseboard heater or do I need a dedicated conduit for the 220? Does a baseboard heater need a switch in addition to a thermostat?
Thanks,
jodywoj is offline   Reply With Quote
Old 09-25-2009, 08:11 PM   #2
dSilanskas's Avatar
Depends on the size of EMT you have and how many wires you have. You need to make sure you keep your conduit fill down. You don't need a dedicated conduit for the heaters. Also you don't need a switch along with the t stat.
dSilanskas is offline   Reply With Quote
Old 09-25-2009, 08:18 PM   #3
Code05's Avatar
Rewards Points: 1,104
Originally Posted by jodywoj View Post
Can I run 2 additional 12 gauge wires in existing EMT for a baseboard heater Yes, if the conduit is large enough and the wire can be derated and still carry the loads/draw.
or do I need a dedicated conduit for the 220? Depends on my earlier statement, 120v and 240v loads can usually be run in the same conduit
Does a baseboard heater need a switch in addition to a thermostat? No switch needed if it is a two pole/double line break T-stat.
Thanks,
1. What size conduit?
2. How many existing wires? What size?
3. Is the EMT the grounding conductor/ground connection? Does the EMT go completlely back to the panel?
Code05 is offline   Reply With Quote
Old 09-25-2009, 08:27 PM   #4
Rewards Points: 27
It's 1/2 in conduit. Right now there are 2 #12 and 2 #14. The emt is the ground. It runs from panel to 4 inch box. I was going to run greenfield from the 4 inch box to the heater.
Old 09-25-2009, 08:36 PM   #5
Code05's Avatar
You are good to go. I ran the calcs.
Old 09-25-2009, 08:40 PM   #6
Code05's Avatar
Define greenfield, it is used in many ways, MC, AC, or metal flex that you install the wires.
Old 09-25-2009, 08:43 PM   #7
Rewards Points: 27
COde 05
I'm not really sure what it is. It's like BX, but without the conducters. I was planning on using 3/8. I gues it's galvanized steel, but I'm not positive.
Old 09-25-2009, 08:55 PM   #8
Code05's Avatar
BX is a trade term often used for AC ( armored cable) , it has an internal ground strap with existing wires. If i read correctly you are using FMT ( flex metal conduit), where you put the wire in your self. You will need to run a ground/ green wire with your two hot wires. Attach the ground wire to the 4" box with a 10/24 screw/ or bolt and nut and then put the other end on the green screw at the unit. Flex does not count as a ground like EMT. Do you understand what I wrote?
Old 09-25-2009, 08:59 PM   #9
Rewards Points: 27
I sure do. Thanks for all the info. This is my first time using this site. It's great to get real help. Thanks again.
Old 09-25-2009, 09:04 PM   #10
Code05's Avatar
You are welcome. Let us know how it turns out.
Old 09-27-2009, 07:28 PM   #11
Ground
Under certain conditions flexible metal conduit is approved as a equipment grounding conductor. Basically not over 6 feet in lenght or more than 20 amps.
007brian is offline   Reply With Quote
wiring a 240V baseboard heater 777 Electrical 10 05-17-2009 10:47 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Wiring a 220 Baseboard Heater joedadog Electrical 8 10-06-2008 06:17 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 03:32 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
