Wiring 220 Into Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2009, 09:09 AM   #1
wiring 220 into sub panel
I have replaced a double pole breaker in the main panel that ran a direct 12/2 with ground wire into a 220 volt compressor with a 100 amp breaker that feeds a new sub panel. I put in a double pole breaker in the sub panel and hooked up the two hots to the breaker from the compressor. The sub panel is not bonded neutral to ground. The question is the bare ground wire from the compressor, does it connect to the neutral or the ground bar in the sub panel? Thanks.
danma is offline   Reply With Quote
Old 07-28-2009, 09:13 AM   #2
You put a 100A breaker in the main panel to protect a 12 gauge wire? You can use 12/2 to feed a sub panel.
jerryh3 is offline   Reply With Quote
Old 07-28-2009, 09:40 AM   #3
I wanted to run 4 new circuits and had no more room in the main panel. I took out a 20 amp 2 pole breaker which connected to an air compressor 220 volt with a 12/2 w/ground. I put in a new 100 amp breaker into the main panel where the 20 amp came out and ran #3 copper into the sub panel along with a #8 ground. This is the main breaker for the sub panel. I am now going to put the 12/2 into the sub panel with a 20 amp 2 pole breaker. I am not sure if the bare ground from the compressor connects to the ground bar or the neutral bar in the new sub panel.
Old 07-28-2009, 10:15 AM   #4
The bare from the compressor should go to the ground bar. No neutral is needed in a 240V circuit.
Old 07-28-2009, 10:28 AM   #5
Thanks, really appreciate the help
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Sub panel wiring question mntnvew Electrical 13 03-02-2009 11:28 AM
Wiring a sub panel? motorcity11 Electrical 8 10-23-2008 02:02 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
