Wiring For A 220 - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2010, 11:53 AM   #1
Rewards Points: 27
Wiring for a 220
I have a device that is rated for 208-240V wiring (table saw). It has a NEMA 6-15P on the end of the cord. I understand that I put in a 15 AMP double pole breaker in the box, but my question is, can I use a two wire? Take a white wire (put black electrical tape on it) and put it on one side and then take the black and put it on the other side and connect the bare copper wire (obviously) to the green copper connection?
This is for a garage application (a table saw) and I assume it requires a ground fault, I assume that the break found at this link would work (I have a homeline panel)?
Thanks,
marly
marly is offline   Reply With Quote
Old 06-20-2010, 01:18 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
yes that would work,although id suggest running anything in a garage other than lights on a minimum 20a circuit with 12 ga wire.
plummen is offline   Reply With Quote
Old 06-20-2010, 01:21 PM   #3
Rewards Points: 27
I was thinking of upgrading it to 20a circuit with 10 ga wire because the distance will be close to 75 feet. I think the 10 ga will be a little better for the equipment than 12 ga for voltage loss.
marly
Old 06-20-2010, 01:54 PM   #4
plummen's Avatar
if your running that far id suggest putting a sub panel in the garage and feeding garage circuits from it
Old 06-20-2010, 02:59 PM   #5
Electrical Contractor
kbsparky's Avatar
You can easily install a 20 Amp 240 Volt circuit using 12-2 wire. Just re-identify the white wire to another color, to indicate it is an ungrounded circuit conductor.
Since you are using a 240 Volt circuit for this load, using #10 would be a waste of money, IMO. Any voltage drop would be minimal, even with a #14 conductor.
You do not need GFCI protection on 240 Volt circuits. The requirements of section 210.8 of the NEC only apply to 120 Volt receptacles.
-KB
Old 06-20-2010, 03:10 PM   #6
If the garage is detached then you can either:
Run one circuit
Run 2 circuits as a MWBC
or run a sub
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
