Wiring 20amp Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 03:42 PM   #1
Rewards Points: 335
wiring 20amp outlet
I am in a kitchen remodel, I need to wire at least a couple outlets up for power, the electric contractor has what looks to be (2) black wires and (1) white wire and a copper ground in a few of the boxes and there is another outlet with (2) black (2) white and a copper ground. The last outlet is at the end of the run and has (1) black, (1) white, and a copper ground. I have seen the last two examples but not the first?
How would I wire this:
titan7 is offline   Reply With Quote
Old 01-20-2011, 03:58 PM   #2
Without seeing the set up, I'm thinking that the first device box you described is either intended for a 240V outlet for an electric stove, or that he is intending to wire the appliance circuits as a multi-wire branch circuit.
For a 120V 20A receptacle, you only connect one hot (black) and one neutral (hot).
To properly answer this question, we need to know how the wires are terminated at the service/sub panel. If you need temporary power for the remodel, the easiest solution would be run a heavy extension cord from another room.
clashley is offline   Reply With Quote
Old 01-20-2011, 04:14 PM   #3
Rewards Points: 335
I think I will wait for them to come back, not worth death or causing a fire.
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 06:25 PM
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 10:54 AM
adding 20amp outlet for for welder Geophile Electrical 12 05-03-2007 08:17 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 08:10 PM
