Wiring A 20amp/250 NEMA 6-20R Receptical - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 06:09 PM   #1
wiring a 20amp/250 NEMA 6-20R receptical
I have a nema 6-20 20amp./250v receptical that I need to install. From out of the outlet in the wall, there is two hot wires (blk & red), a return (wht), and the ground (bare copper). The receptical that I have only has three screws for the connections, two for the hot and the one for ground. My question is, how or where do you connect the return wire? Thank you for you wisdom. Jim.
jgapiaries is offline   Reply With Quote
Old 11-13-2012, 06:10 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You don't, just cap it off.
Old 11-13-2012, 06:17 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 820
The recept you have is a 240Vac only outlet. For that application, you would hook up the black & red wires only (and ground). The white neut wire could just be wire nutted for safety. You only need the neut if your device also needs 120Vac.
Some of the experts might chime in...but I think standard now is to use a 4 wire connector. If your device does not use the neutral...that ok...no harm.
What are you wiring up?
I just wired up one of those this past weekend for my 240Vac compressor.
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 11:00 AM
wiring a receptical with 3 wires? mac16m83 Electrical 3 04-11-2011 08:47 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 01:17 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
