Wiring 2 Pole GFIC Breaker In Sub-panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 07:20 AM   #1
Wiring 2 pole GFIC breaker in sub-panel
Hello,
I have a whirlpool tub and a steam generator that are both 3 wire, 2 hot and a ground, which I believe means they are 240 volt circuits that require 2 pole GFIC breakers installed in a sub-panel. If I understand correctly the 2 hots are wired into the breaker, the ground from the appliance goes the the ground buse bar, the neutral from the breaker is wired to the neutral buse bar and the neutral on the breaker remains empty.
Thank you in advance.
Joe
J_etten is offline   Reply With Quote
Old 08-18-2012, 07:24 AM   #2
Rewards Points: 1,298
Assuming this is a question, then ,yes, you are correct. The neutral pigtail from the breaker is used to test the circuit when you push the test button
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
J_etten (08-18-2012)
Old 08-18-2012, 07:29 AM   #3
Yes it was suppose to be a question Thank you!
Tags
2 pole gfi breaker
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Modify a breaker panel cover. rrolleston Electrical 14 03-10-2012 05:59 PM
Can a Square D 4 pole circuit breaker be used as a 2 pole circuit breaker. TifcoJim Electrical 3 08-23-2011 11:59 PM
Fake Double Pole Breaker in Pushmatic johnk88 Electrical 17 03-01-2011 10:37 PM
Bad breaker panel??? drjay9051 Electrical 9 08-25-2010 03:43 PM
