Old 05-13-2010, 04:40 PM   #1
Question
Wiring 2 Motion Sensor Flood Lights Through Siding
Hello,
My wife and I recently bought a house and on the house there was on motion sensor flood light and another flood light off to the side of the house. They put an light socket plug adapter in one of the light sockets and then plugged the other flood light (without the motion sensor) to that adapter. Therefore, once the motion sensor went off both lights would come on. Well, I want to replace both lights with two new motion sensor lights.
This is my plan:
Wire one new motion senor flood light to the existing wires. Then run UF-B 14/3 cable underneath the siding of the house to the other motion sensor flood light on the side of the house. Is this okay or should I use MC cable instead?
By the way, I am using 14/3 with ground so I can tie the motion sensors together so when one senses motion, the other one does too.
Also, I live in Alabama.
Thank you
Datwood2009 is offline   Reply With Quote
Old 05-14-2010, 11:01 PM   #2
Just call me Andrew
bump for Datwood
Andrew
secutanudu is offline   Reply With Quote
Old 05-15-2010, 10:26 AM   #3
J. V.'s Avatar
And they say people from Alabama are dumb............LOL. Kidding. I like the idea of the 3 wire cable. Good thinking.
Old 05-15-2010, 11:16 AM   #4
Master Electrician
[quote=Datwood2009;441518]Hello,
This is my plan:
Thank you[/quote
You need to specify whether or not you are trying to operate both floods from the MD on one of the floods, operating the floods from MD on each flood, or whether you ar trying to operate both floods when motion is detected from one MD or the other. Independant operation is much easier than trying to get themto operate in tandem.
brric is offline   Reply With Quote
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 11:39 PM
Wiring a Motion Sensor Flood Light Boompoopah Electrical 13 11-12-2009 03:00 PM
Permenant wiring of undercabinet lights Steven Electrical 1 11-16-2006 11:53 PM
Wiring for external lights and outlets MikeinBurien Electrical 4 12-05-2005 01:16 AM
activate other lights when motion light activates John Electrical 3 02-10-2004 08:53 PM
