Wiring 2 Light Fixtures To Same Switch And Add Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 09:14 PM   #1
Wiring 2 light fixtures to same switch and add outlet
In my bathroom I currently have an overhead light, a vanity light, and a ceiling fan. I have 3 switches on my switch panel, each controlling one of the items (each light has its own switch, and fan has its own).
What I want to do is control both lights from the same switch, keep the fan on its own switch, and use the now-empty slot for an electric socket (GFCI outlet).
There are 3 white wires that go into the box, they are combined together, not connected to anything.
I've attached pictures.. If you cant make out whats going on:
- 1 set of wires entering the box from the bottom center, black\white\copper.
- Two sets of wires entering the box from the top, one set on each left and right, each with black\white in it.
In the box:
The white wires from all 3 sets are bundled together with a connecter.
The black wire coming into the box from the center is pigtailed and there is a wire from this connection going to the bottom screw of all 3 switches.
The black wire coming from the wire sets on the top left\right side is connected to the top screw of the switches that control each light.
There is also a red wire that leads into the same hole where the top right bundle is entering which is connected to the top screw of the fan switch.
Switch order is pictured.
Leftmost = ceiling light
center = ceiling fan
rightmost = vanity light
Want to go from:
Switch - Switch - Switch for Light - Fan - Light
to
Outlet - Switch - Switch for n\a - Fan - Light+Light
Any help is appreciated, let me know if more info is needed.
Wiring 2 light fixtures to same switch and add outlet-pic1.jpg   Wiring 2 light fixtures to same switch and add outlet-pic2.jpg   Wiring 2 light fixtures to same switch and add outlet-pic3.jpg
RyanS2000 is offline   Reply With Quote
Old 10-08-2010, 10:01 PM   #2
My belief is as follows:
-Disable power.
-Remove left switch (two black wires are now disconnected - one from wire nut and one directly out of box).
-On right switch, locate black load wire (not from wire nut group) and remove from switch
-Connect together the two load wires formerly from the left and right switches, along with a short pigtail of black-insulated wire
-connect the new pigtail to the right switch
-Add a white pigtail to the existing bundle of white wires
-Connect the black pigtail formerly connected to the left switch to the GFI supply connection
-Connect the newly added white pigtail to the GFI neutral connection
All devices should also be grounded
Restore power. Check things for correct operation.
oberkc is offline   Reply With Quote
Old 10-08-2010, 11:41 PM   #3
Worked like a charm! Thank you so much.
Old 10-08-2010, 11:42 PM   #4
Just call me Andrew
Rewards Points: 1,020
By code, an outlet can only be added to this circuit if BOTH of these are true, which is unlikely:
1. This circuit is 20 amps.
2. This circuit serves this bathroom ONLY.
A circuit can supply power to either:
1 bathroom, outlets and lighting/fan
or
Multiple bathrooms, outlets ONLY
I don't know if this rule applies since this is an existing circuit, but since it is being changed, it might.
Obviously it works despite being against code, and I don't really think this is a safety issue, other than the possibility of tripping a breaker with a hairdryer or something and being left in the dark.
Andrew
secutanudu is offline   Reply With Quote
Old 10-08-2010, 11:44 PM   #5
or
Will the circuit box/breaker let me know of amperage?
How do I confirm this? When I shut off the breaker for this bathroom in the basement, only this bathroom loses power.
Old 10-08-2010, 11:49 PM   #6
Just call me Andrew
The breaker should have the amperage stamped right on it. On some breakers it can be hard to read, but it should be there somewhere...
So that circuit only powered 2 lights and a fan? Would be very code-friendly if so to add an outlet (if it's 20A) but I would think something else is powered by that circuit...maybe not though since maybe this bathroom was added later on, being that it's in a basement?
Andrew
Old 10-08-2010, 11:55 PM   #7
Believe it or not, yes. The entire box is labeled and the breaker for the bathroom is labeled "MB Bath"; when I flipped the breaker, no other part of the house lost power..mind you, it's a 3BR ranch home.
My wife and I just purchased the house in March of 09, the previous owner (was original owner) from what I've been told worked for the electric company so I'm assuming he was on top of the electrical wiring in the home. Aside from electricity, every aspect of the home was meticulously cared for.
Also, do you agree with the wiring instructions posted above? I followed them exactly and it does work exactly how I wanted.
Old 10-08-2010, 11:59 PM   #8
Just call me Andrew
If it's working as you want, the instructions were correct
Andrew
Old 10-09-2010, 12:02 AM   #9
Checked amperage, 15A. My only worries are tripping the breaker if too much current is being pulled, correct?
Old 10-09-2010, 12:06 AM   #10
Just call me Andrew
I believe so, yes.
Andrew
Old 10-09-2010, 05:12 PM   #11
regarding code, I know only what I have learned from places like this. I understand existing structures are not required to be upgraded, but if changes are made, then one is compelled to bring it up to full code compliance. (Perhaps others can confirm this.) In the world of code, there appears to be little gray area.
In my world, however, I find gray areas. I often ask myself the question about whether a change is safer than before, even if not fully code compliant. Is a GFI outlet safer than a non-GFI outlet (or no outlet?) even if it is on only a 15a circuit? Is it safer even if there are other non-bath outlets on the same circuit? I know how I would answer these questions.
I defer to the experts about the code compliance issue, but for me, I find the decision about whether to push ahead includes many considerations.
Old 10-09-2010, 06:51 PM   #12
Just call me Andrew
I agree. In this case, having an outlet on a 15A circuit serving only one bathroom...I'd probably do it myself the same way rather than run a new circuit for that outlet.
Andrew
Old 10-10-2010, 12:33 AM   #13
Must be GFI in bathroom!!! what you are doing is not code compliant but it will work, but for safety please put in a GFI
jddavis is offline   Reply With Quote
Old 10-10-2010, 03:17 AM   #14
" Euro " electrician
frenchelectrican's Avatar
The other thing you have to check the grounding conductor{bare conductor} to make sure they are landed on the box I know most older home the chance to find the grounding conductor can be like long shot due some of the older NM do not have any grounding conductor in there.
If that the case you have to install the sticker on say no equiment grounding simuair to like that.
Merci,
Marc
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
Wiring a light with switch....please help!! lindo1951 Electrical 19 10-16-2006 03:32 PM
