Wiring Of A 2-Bulb Halogen Motion Outside Light - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2013, 03:22 PM   #1
Wiring of a 2-Bulb Halogen Motion Outside Light
Hello,
I installed a new Outdoor 2-Bulb Halogen Motion Light from an outlet in a Utility Room, into a new Box Inside, through the outside wall and into another Outside Box. I did run a Ground Wire from the Existing Outlet to the new Outside Box.
When I ran the wiring to the Light itself, from the new Outside Box all I used was a Black and White (no Ground Wire). I did, however, ground the Light's Ground Wire to the Light's Box which is metal.
The Light functioned fine with just the Black and White wires. I think the other day we had a power surge or something. Now the Lights do not come on even though the Motion Red Light is coming on. I replaced both Halogen T3 bulbs (they were both Blown) and the Lights still do not come on.....not even in the Test Mode. Do I really have to connect the Ground Wire from the new Outside Box to the Light? By not having the Ground Wire attached, could that have led to the Bulbs Failing and may have caused the Motion Circuitry to have been damaged also?
I want to replace the Motion Light now, but do I really have to run the Ground Wire through the Conduit to the Ground Wires of the Light?
fixit66 is offline   Reply With Quote
Old 11-12-2013, 08:12 PM   #2
Licensed electrician
Rewards Points: 1,022
The sensor may be fried and need to be replaced.
Philly Master (11-12-2013)
Replacing a light bulb 94dgrif Electrical 2 01-13-2013 01:38 PM
need help changing out light bulb gswarriorfan Electrical 13 04-17-2012 09:43 AM
rough wiring garage for exterior flood lights with motion detectors jwalk2c Electrical 3 02-23-2012 08:53 PM
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 03:00 PM
