Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2013, 06:26 PM   #1
Wiring
i have power coming to the switch with two wire then it goes to an overhead light. I would like to then run the wire from the light to a recp. Is there a way to keep the recp. live when the switch is off for the light
rslove is offline   Reply With Quote
Old 10-22-2013, 08:04 PM   #2
An old Tradesmen
Rewards Points: 6,072
Moved to Electrical forum.
Old 10-22-2013, 08:25 PM   #3
Licensed electrician
Not if you only have a 2 wire cable from the switch to the light.
Old 10-22-2013, 08:34 PM   #4
DIY Enthusiast
sublime2's Avatar
How many wires are at the light?
The wire running to the switch, are they black and white?
If they are, odds are the power is at the light.
sublime2 is offline   Reply With Quote
Old 10-22-2013, 09:32 PM   #5
Rewards Points: 150
If you have a black and white wire attached to the switch, then yes you can run power from the light to your outlet. If you have two blacks on the switch and capped white wires, then you can either pull a three conductor wire from the switch to the light, pull power from the switch box, or just run a new circuit (recommended)
romex1220 is offline   Reply With Quote
Old 10-23-2013, 12:32 AM   #6
dmxtothemax's Avatar
Rewards Points: 5,096
No you cannot run a recepticule from a switch loop !
As there is no neutral or ground there.
You must come from the light,
Cause that's were the neutral and hopefully the ground is !
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
sublime2 (10-23-2013)
Old 10-23-2013, 01:04 AM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
In the US, grounds are required at switch locations....
Old 10-23-2013, 05:56 AM   #8
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
FROM THE SWITCH location .. OP said power comes to the switch ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 10-23-2013, 05:35 PM   #9
OK !
If power and neutral goes first to the switch,
Then YES ! you can run power to a recepticule,
But remember you need to have Neutral and hot,
Not just a hot.
So if your sure that a neutral is there, your fine !
Don't forget to ground it too !
Old 10-23-2013, 07:01 PM   #10
Rewards Points: 516
if you open up the switch and the are 2 cables 2 whites and 2 blacks .....and the whites are tied together and the remaining 2 blacks go to each screw of the switch then you have the FEED there ....
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
