Old 03-12-2013, 02:40 PM   #1
wiring
what will happen if I replace 15 amp receptacle with a 20 amp receptacle. The breaker on the circuit is a 20 amp
papasicle is offline   Reply With Quote
Old 03-12-2013, 02:48 PM   #2
Electrical Contractor
wiring
Nothing, but it is not required.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-12-2013, 03:02 PM   #3
wiring
Why would you even want to?
The Following 3 Users Say Thank You to joecaption For This Useful Post:
NJMarine (03-12-2013), Speedy Petey (03-12-2013), stickboy1375 (03-12-2013)
Old 03-12-2013, 03:09 PM   #4
Licensed electrician
wiring
I doubt that you even have anything with a 20 amp cord cap.
The 15 amp duplex is still good for 20 amp feed-through.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
Old 03-12-2013, 07:16 PM   #5
E2 Electrician
stickboy1375's Avatar
wiring
You will waste your time and money.
stickboy1375 is online now   Reply With Quote
Old 03-12-2013, 07:59 PM   #6
wiring
You will have a newly installed 20 amp receptacle.
jlmran is offline   Reply With Quote
Old 03-12-2013, 08:01 PM   #7
wiring
Maybe the 15 failed and he has a 20 on hand?
Could be dozens of reasons.
The Following User Says Thank You to jlmran For This Useful Post:
Kyle_in_rure (03-12-2013)
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
