Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 07:28 AM   #1
wiring
I have a Light in the pantry and a light in the kitchen. The wires come from the panel to the bottom of the first switch box. The switch/plug combo are the first to wire to. I want the switch to work the pantry but keep the plug part hot at all times. But I also need power for the kitchen light via using a dimmer switch. Do I need a three way dimmer switch to make it work? And how do I wire it? Thanks.
heavychevy is offline   Reply With Quote
Old 06-26-2012, 07:32 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You do not need a 3 way dimmer. I'm sure Hammer will be along shortly to give you a diagram.
Old 06-26-2012, 08:33 AM   #3
Rewards Points: 2,516
You left some information out as far as the location of the switches and receptacle.....so Assuming both switches and the receptacle are in the same box:
hammerlane is offline   Reply With Quote
Old 06-26-2012, 08:49 AM   #4
I see you said switch/outlet combo so here is another diagram. Follow wiring diagram for your switch/outlet combo. ALways HOT wire to brass terminal for outlet and to line terminal to switch.(shown as black wires in diagram for switch/outlet combo), load power to light to load terminal of switch(shown in red in diagram), then neutral wire to the silver terminal of the outlet.
The Following User Says Thank You to hammerlane For This Useful Post:
k_buz (06-26-2012)
Old 06-26-2012, 05:03 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why not just reverse the red wire and the black wire at the switch/receptacle combo and not break the tab out?
Old 06-26-2012, 07:38 PM   #6
Why do it like that?
Old 06-26-2012, 07:58 PM   #7
E2 Electrician
Why run two pigtails to the switch when only one is required? No need to break the tab out unless two seperate circuits are being used.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
