Old 04-20-2012, 12:26 PM   #1
wiring
i want to wire a plug into an existing outlet
blampkin is offline   Reply With Quote
Old 04-20-2012, 12:31 PM   #2
wiring
go for it!
itsnotrequired is offline   Reply With Quote
The Following 2 Users Say Thank You to itsnotrequired For This Useful Post:
HIVOLT (04-20-2012), jbfan (04-20-2012)
Old 04-20-2012, 02:39 PM   #3
Lic Electrical Inspector
electures's Avatar
wiring
Usually we just insert them. It's easier and safer.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 04-20-2012, 03:20 PM   #4
joed's Avatar
wiring
Plugs just plug into outlets or receptacles. No need to wire them in, even in Canada.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-20-2012, 03:29 PM   #5
kevinp22's Avatar
wiring
In all seriousness we cant exactly tell what you are asking.
Getting picky, "plug" is not really a technical term
"outlet" in technical terms means any place electricuty is used, such as a ficture or a receptacle
A place to plug in cords is an "outlet" but the more precise term is "receptacle" or for extra credit "duplex receptacle"
Is your question one of these:
1. I want to add a receptacle and tap it off a light fixture or switch
2. How do I add a receptacle in a new location off of an existing receptacle
If this is the first wiring you have ever done Im not sure Id do either one but lets take it one step at a time
kevinp22 is offline   Reply With Quote
Old 04-20-2012, 03:49 PM   #6
JOATMON
ddawg16's Avatar
wiring
At least he didn't ask how much it will cost.....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
