Wiring A 12vdc Amplifier To 110v Line? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2017, 10:34 AM   #1
Rewards Points: 16
Wiring a 12vdc amplifier to 110v line?
I am building a shop and I purchased an in-wall amplifier to power some speakers. It is 12v DC.
For some inexplicable reason, they expect you to plug a power adapter into the front of it that you would plug into an outlet. However, it also has wires in the back to be hardwired. I want to hardwire it to a 110v line, but I'm not sure what equipment I need. A transformer I assume, but I haven't had a lot of luck looking online. I mostly just find lighting transformers. Are these the same thing?
I don't want to have to plug this in to an outlet somewhere else, which defeats the purpose of an in-wall plate. Is it even possible to wire this thing up to the romex to keep everything in-wall/receptacle box?
Thanks.
Disgustipater is offline   Reply With Quote
Old 01-08-2017, 11:27 AM   #2
Rewards Points: 46
Re: Wiring a 12vdc amplifier to 110v line?
Thanks.
It does sound silly to have it plug into to front.
Well the transformer would have to be accessible. With all the wiring in the back, I assume that won't be hard to arrange a plug and wall wart. Not sure of the code, but since you can pull out the amp, I'd think it'll be called accessible. Dunno how much space you have though.
Don't forget about air flow for the amp either.
Cheers!
supers05 is offline   Reply With Quote
Old 01-08-2017, 01:14 PM   #3
joed's Avatar
Rewards Points: 12,872
That unit needs a 12VDC input. You can use low voltage cable. You don't need romex. The 12VDC supply could be elsewhere in the house and fed to the amp through the walls along with the speaker wires.
Old 01-08-2017, 02:29 PM   #4
Rewards Points: 16
Assuming the transformer was small enough, I could stick the amp and transformer into a 2-gang box.
Where would the supply come from? I don't want it plugged into another outlet.
Old 01-08-2017, 02:35 PM   #5
Rewards Points: 46
I finally looked at the manual. There's 2 ways of connecting power.
Connecting Power: Under normal circumstances, power is connected to the front panel power input via the included AC adapter. Power may be supplised from an alternative 12V DC power source via the rear pigtail RED+ / BLACKS leads (for hard-wired installations).
Cheers!
Old 01-08-2017, 02:43 PM   #6
Rewards Points: 16
What would the "alternative 12V DC power source" be?
Old 01-08-2017, 03:00 PM   #7
Rewards Points: 46
Quickly looking, all I've found are wall warts or inline adapters that are way overkill. I think that you're stuck with the wall wart. You might be able to hide it somewhere like in a utility room. Just watch out for the voltage drop, as it's worse for DC, and lower voltages. (and electronics like this will be sensitive to low voltage) IE. Don't make the run too long.
Cheers!
Old 01-08-2017, 03:08 PM   #8
Rewards Points: 16
Okay, let's say I give up and use the wall wart. Can I cut the DC plug off the end, attach it to the wires in the back of the amp, and run the wire in the wall two feet down, come out right next to an outlet and plug it in there?
Old 01-08-2017, 03:38 PM   #9
Rewards Points: 46
That's what I would do.
Cheers!
Refrigerator Water line install & Electrical sMcGp Plumbing 7 08-05-2015 03:40 PM
installing refrigerator ice maker line xnera Plumbing 13 07-11-2013 07:11 PM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 02:29 PM
Wiring an old 220 line to a new plug Charles.SC Electrical 3 03-28-2011 06:46 PM
wiring 50a 220 line mgarfield Electrical 2 07-27-2008 10:44 PM
