#1 |
wiring
I want to wire a Leviton programmable timer to my outdoor lights. The Leviton has a black, red, white, orange (for 3 way) and green wire. The box has one black, one white and one ground wire. I am ignoring the orange wire since there is only one switch controling the lights. I have wired the timer green to the ground and the whites together. What to do with the black and red from the timer and the black at the box?
#2 |
Average Joe/ex-Navy IC3
wiring
It will not work, if there is a "Switch Leg". You need a Neutral, which would mean having four wires, not just three, so that you can use the timer. If you can pull 14/3, that would allow you to use the timer.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| Display Modes | |
| Cloth Wiring - Replace? | JessicaGus | Electrical | 9 | 09-23-2009 07:45 PM |
| electric wiring in house remodel | wis_remod | Electrical | 6 | 04-02-2009 03:40 PM |
| Wiring diagram for three-way switches with pilot light | SaxTeacher | Electrical | 33 | 03-18-2009 08:11 PM |
| New Home Wiring - Seeking Expert Advice | Dirtrnr | Electrical | 3 | 02-10-2009 11:33 AM |
| Knob & Tube wiring - How concerned should we be? | hotdiggitydog | Electrical | 6 | 04-11-2006 08:52 PM |
