Old 11-28-2009, 01:08 PM   #1
wiring 100A to detached garage
I am wiring a detached garage with 100a service as sub panel from 200a house panel. I am using 2-2-2-4 SE Aluminum cable from the main panel through the basement into the attached garage (in schedule 40 PVC once the cable enters the attached garage, since I am running the cable exposed, i.e. not buried in the wall cavity). I then switch to type W XLPE 4 wire (2 hot, neutral, gnd) in a junction box using aluminum split bolt connectors, wrapped in Scotch 130c, then Scotch super33. This continues out of the attached garage 2ft below grade and into the detached garage (all in sch 40 PVC 2"). Grounding rod at detached garage, ground bar bonded to panel with the included green screw, neutral bar isolated from panel and from ground bar. I need a sanity check on what I have done so far, does this sound correct? I am in process of making final connections.
Also (my main question), where the cable enters the detached garage, the 2" conduit comes through the slab floor where I use a LB box and run the cable inside the wall cavity about 8 feet to the 100a panel. I seem to recall reading something about having to switch the type of cable once it enters the detached structure, i.e. can't use the W XLPE 4 wire cable in the wall cavity? Does this make sense and do I have to switch to a different cable type? Thanks for the help.
snowman is offline   Reply With Quote
Old 11-28-2009, 04:41 PM   #2
.....Nope
220/221 is offline   Reply With Quote
Old 11-28-2009, 05:00 PM   #3
thanks. Everything else seem correct?
Old 11-28-2009, 05:16 PM   #4
dSilanskas's Avatar
Seems good to me
dSilanskas is offline   Reply With Quote
Old 11-28-2009, 05:53 PM   #5
Licensed Pro
A nit-picky inspector may require you to use a 90A breaker instead of a 100, but other than that, it sounds OK.
Wiring Main-Breaker Box in Detached Garage wstribl Electrical 15 05-11-2013 06:15 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Wiring Diagram for Detached Garage jamiedolan Electrical 0 02-07-2009 10:43 AM
help wiring detached garage to code ugabulldog Electrical 7 08-05-2008 09:48 AM
wiring detached garage ugabulldog Electrical 5 07-24-2008 05:13 PM
