Wires Too Short In Panel / Loadcenter - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 09:40 PM   #1
wires too short in panel / loadcenter
After having a new loadcenter installed by professionals I found out that my detached garage no longer has power.
I found the wires to the garage where not connected to a breaker, and the wires will not reach to where I can install a breaker in the panel/electrical breaker/loadcenter.
I suspect that using wire nuts to extend the wires inside the panel would not be code. Is this true? As it would be the fastest and easiest solution.
Other ideas, are to lower the outlet box in the garage so I can get an extra 6 inches or so and then hope that the wires are free/loose enough to be able to pull them to get the extra length I need.
Last option is to replace the cables and hope that it will be easy to get the new cable passed without have to crawl under the house and dig up the asphalt between the house and garage.
The loadcenter is from Eaton/Cutler Hammer, are there way to extend the bus/rail so I can add a break lower down so that the existing cables can reach?
Sorry for the long question - thank you for all answers in advance.
houselost is offline   Reply With Quote
Old 06-04-2009, 09:46 PM   #2
You can use wire nuts in the load center to extend the wires
This is acceptable under code
Old 06-04-2009, 09:53 PM   #3
300zx's Avatar
Post
+1
300zx is offline   Reply With Quote
Old 06-04-2009, 10:35 PM   #4
If soldering or crimp splices
http://www.allproducts.com/manufactu...t_splice-l.jpg
are not forbidden by code I'd do that.
Wirenuts are not always forever.
Old 06-04-2009, 10:43 PM   #5
300zx's Avatar
Post
If done right,(Twist wires together) Wirenuts Will last forever.
Old 06-05-2009, 09:48 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
I would call the professionals back and have them fix it!
Old 06-05-2009, 11:09 AM   #7
Rewards Points: 78
AGREE!!!!!!! They did not complete the job. I would have called them yesterday.
Old 06-05-2009, 12:29 PM   #8
How often are they done right?
Is there a way to tell if they were done right (beside measuring contact impedance)?
I couldn't find any data on wirenut reliability, or the overall reliability/skill of the people installing them. Compared to screw terminal methods, for example.
Old 06-05-2009, 06:11 PM   #9
300zx's Avatar
Post
Are they UL listed?.
Making good, solid solderless electrical splices begins with selecting the right size connectors for the splice. What size connectors you will need depends on the size of the conductors being spliced together and the number of conductors in the splice. I’m not one for reinventing the wheel and the Ideal™ Corporation, a manufacturer of Ideal Wire-Nut® wire connector has made available a connector selection chart that’s approved by the Underwriters Laboratory for UL Listed Wire Combinations. Every DIY electrician needs to download and printout this pdf file for future reference. This is a good time for you to start building your reference library. Like professional electricians you should start a MSDS (Material Safety Data Sheet) reference file at this time too. The MSDS in pdf file format can be downloaded and printed out here.
The most common size splices made by the DIY electrician involve a combination of AWG (American Wire Gage) sizes 14, 12 and 10 copper conductors and Ideal 92® (green), 451® (yellow), 452® (red) and 454® (blue). These numbers are strictly applicable to the Ideal line of wire-nuts but the colors apply to all brands of screw-on wire connectors. The “Greenie” or grounding wire-nut is especially designed to make grounding pigtail splices easier with a hole in the end of the cap.Wire-nuts makes making good solid splices so easy that anyone can learn to do it after a few minutes practice
Old 06-05-2009, 07:00 PM   #10
Thanks for the bookmarks.
Old 06-05-2009, 07:10 PM   #11
Yeah
Way to go Scuba that's the ticket.
SULTINI is offline   Reply With Quote
Old 06-05-2009, 07:12 PM   #12
Very good point
They should not have left this disconnected
Old 06-05-2009, 08:23 PM   #13
Rewards Points: 2,350
I have had situations where I have swapped a panel out and encountered a cable that was not correct for the load and refused to hook it back up. For example, I found a 14-2 NM connected to a 30 A double pole that went right into the dirt to feed a shed, and a piece of speaker wire that fed a doorbell transformer in the attic. Both in the same panel. I informed the customer there was no way that I was going to put power back on either of those circuits unless they were corrected. This particular guy almost got PO'd. He told me that there was nothing wrong with it (because he installed them!), and knew someone who would hook them up. It wasn't me.
Old 06-05-2009, 08:40 PM   #14
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
My helpers seemed to think they were to be used as "one hitters"
wirenut1110 is offline   Reply With Quote
Old 06-05-2009, 08:56 PM   #15
300zx's Avatar
Cool
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 03:05 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
Short Wires sensen Electrical 3 04-01-2005 01:36 PM
