Wires Through Sistered Floor Joist Into Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 09:39 AM   #1
Rewards Points: 640
Wires through sistered floor joist into wall?
I have a wall that goes from concrete on one end to open on the other end... basically a single wall that doesn't form a room, just a divider... I need to get power into the wall though, above it when it was framed was sistered floor joists... so the entire 2x4 wall's top is closed off to run straight up...
Can you just drill up and out at an angle and put metal plates on the top plate to protect the cable to get around this? or is that a no no by code?
I can't find any other way to get around it
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 08-22-2012, 11:19 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
I can't see in my mind what you are talking about.
Can you post a pic?
Old 08-22-2012, 11:36 AM   #3
Rewards Points: 640
Can you post a pic?
did a quick drawing, with a wire kinda showing the only path I have
not 100% accurate, the block wall doesnt go above the top plate but its just an idea of how it is
Old 08-22-2012, 02:55 PM   #4
jbfan's Avatar
Rewards Points: 552
Gothca!
Yea, drill at an angle and install nail plates where needed.
The Following User Says Thank You to jbfan For This Useful Post:
BlueBSH (08-22-2012)
Old 08-22-2012, 02:59 PM   #5
Rewards Points: 640
Gothca!
Awesome, thanks! Wouldn't know how to get around this if that wasn't the answer
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Creating a hole in the wall to run wires, a good idea? RyanD General DIY Discussions 6 05-19-2009 03:30 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
