Wires Through Meter Socket Enclosure - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 12:19 PM   #1
Question
Wires through meter socket enclosure
I am installing a new underground service to a small house. I am also setting a subpanel in a remote barn. I have two 2-1/2" conduits coming up the stem wall of the house foundation, one for the service and one to the barn. Service conduit will lead up outside wall to surface mounted meter socket box. My 200a house load center will be inside behind the meter socket connected by a bushing. All normal so far I think. I am thinking it would be nice to run the barn conduit to the socket box entering the bottom on the other side from the service conduit. Then the 4 #6 wires to the barn could share the same bushing as the metered service wires into the house load center. I think this can be all done in the area of the socket box that the utility highlights as customer wiring. Other possibility is to pop a second hole through the wall below the box and load center and bring barn wires coduit in through a pair of 90s with access covers.
My first idea seems cleaner. If the bushing between box and center is big enough (how big?), would this be OK per NEC? Should I call my AHJ (or a local electrician? I'm an adventurous mechanical engineer with a copy of the 1999 NEC doing my own wiring (again).
ddellario is offline   Reply With Quote
Old 03-03-2012, 12:27 PM   #2
MarginallyQualified
Rewards Points: 2,464
Trough box under the meter... using Polaris connectors for the several feeds.
Old 03-03-2012, 04:26 PM   #3
Rewards Points: 3,256
You will have the fused barn and unfused service conductors in the same space which is not permitted.
Your second idea sounds much more traditional.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
Julius793 (03-03-2012)
Old 03-03-2012, 04:41 PM   #4
Thanks TH & Zappa. Makes sense. I'll go with plan B.
Tags
customer wiring , meter box
Drop Wire (From Weatherhead to Meter) roadman1977 Electrical 7 12-24-2011 11:35 AM
Rigid to meter connection and bonding? iminaquagmire Electrical 2 11-11-2011 10:18 AM
Need to move meter socket Rustygaff Electrical 3 11-28-2010 09:44 AM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 06:35 AM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
