# Of Wires Through EMT - Electrical - DIY Chatroom Home Improvement Forum
Old 12-26-2008, 07:15 PM   #1
Rewards Points: 274
# of wires through EMT
Back again... any code on amount of wires(ex. 12/2) I can run through any size EMT? thanks
ugabulldog is offline   Reply With Quote
Old 12-26-2008, 07:21 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
What kind of wire in what size EMT? Are you talking about running romex style cable in EMT?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 12-26-2008, 07:25 PM   #3
Rewards Points: 274
Jamie
yes, romex
Old 12-26-2008, 07:34 PM   #4
DIY'er
jamiedolan's Avatar
yes, romex
Are you just using it as a sleeve down a few feet of exposed wall?
It is allowed, but not necessarily easy to pull very far in EMT.
NEC 334.15c.
Jamie
Old 12-26-2008, 08:06 PM   #5
Rewards Points: 274
I would be using it in a pole barn on the front or side of a beam since there are no tradional stud walls, about 5' per run down from ceiling.
Old 12-26-2008, 08:11 PM   #6
DIY'er
jamiedolan's Avatar
Should be fine and should be fairly easy to put the NM down that short of a run of EMT.
My only concern would be if this is a weather proof location? It's my understanding that you can not use romex in conduit in a wet location, but would have to research it more if this applies.
Jamie
Old 12-26-2008, 08:21 PM   #7
Rewards Points: 274
thanks jamie, i am going over best way of wiring in my head, (not working of any blueprints) and am thinking of a way not to have to use EMT but rather run conduit all the way up outside wall, enter w/ romex over top plate, run along beams and down one of the "tradional" walls to switch (disconnect). About 20' worth of wiring inside structure before hiting disconnect switch. Does this sound ok for a disconnect? Also, you have to enter barn, then enter feed room door before accessing switch, ok?...thanks
Old 12-26-2008, 08:33 PM   #8
DIY'er
jamiedolan's Avatar
Are you running only 1 circuit to this building in total?
Is the inside of the building finished and waterproof?
In terms of the disconnect the code says:
"(1) Readily Accessible Location. The service disconnect-
ing means shall be installed at a readily accessible location
either outside of a building or structure or inside nearest the
point of entrance of the service conductors."
Jamie
Old 12-26-2008, 08:44 PM   #9
Rewards Points: 274
one circuit, as finished and waterproof as a barn can be (enclosed).
maybe I should put disconnect box on exterior wall, and continue out of box with conduit the rest of the way up outside wall.
Old 12-26-2008, 09:07 PM   #10
DIY'er
jamiedolan's Avatar
The code sound a little subjective, I guess... service conductors is the wire or a person? please forgive my ignorance. Either way it sounds subjective. The feed room door is at front of barn immediatley as you enter and disconnect switch would be behind feed room door once closed. maybe I should put disconnect box on exterior wall, and continue out of box with conduit the rest of the way up outside wall? That might look odd with straight conduit pipe coming in to box and elbow joint coming out.
The local inspector is the person that would have to determine what is considered readily accessible or is considered close enough for the disconnect for them to pass it. They are not more specific in the code as far as I can tell.
You would be really safe with a very basic very cheap weather proof external disconnect (they are like $6). You could run the wire into it in the bottom, in a conduit coming from the ground, then drill through the wall and connect into the back of the disconnect box with a pull elbow, and then have the conduit run up the inside wall. Then just sleeve down the wall to the box with EMT as necessary to keep all romex protected.
Jamie
Old 12-26-2008, 09:11 PM   #11
Rewards Points: 274
Thank you jamie. I tend to over analyze everything, it is a blessing and a curse all at the same time.
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 08:37 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
