Wires Sticking Out Of Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2009, 04:12 PM   #1
Question Asker
Send a message via AIM to xamplesample
Wires Sticking out of Ceiling
when i moved in to this ol' house, there was a broken ceiling fan lying on the floor. and 3 wires sticking out of the ceiling, blue, black, and white. if i want to put in a new fan, are these all the wires i need, or is there possibly another wire that got pulled back up into the ceiling. KEEP IN MIND THIS IS AN OLD HOUSE WIRED OLD SCHOOL.
xamplesample is offline   Reply With Quote
Old 01-24-2009, 04:25 PM   #2
DIYer
Blue wire is kind of strange. Are you sure you are looking at the real junction box and not part of the old fan?
Gigs is offline   Reply With Quote
Old 01-24-2009, 05:15 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I would say there is a good chance your fine. In Illinois equipment ground was often carried by metal conduit of some type. I am assuming there is a switch box on the wall with 2 switches?? You have a good chance the black and blue are switched hots and white neutral and metal conduit is your ground. It is also possible that one hot is constant hot with fan controlled by pull chain and the other switched at the wall for the light. Get a voltage tester and see what voltages you get on those wires measured to ground.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-24-2009, 08:19 PM   #4
If it's old enough there wouldn't be any grounds. I highly doubt his whole house is piped..... I would cap off all three wires with a wire nut then take a tick tracer, and see what you have for hots. Also do like in the above post, and check what you got going to your switch. Ben
swaterbenny is offline   Reply With Quote
Old 01-25-2009, 12:25 PM   #5
Rewards Points: 204
If you have two switches and three wires you are good to go. Use the blue for the light, black for the fan and white for the neutral.
Look inside the box. There could be a bare or green wire connected to the box. If there is, just extend this ground wire to the fan housing. If the box is metal, the box and fan both must be connected to the ground wire. If you have conduit, the conduit itself is considered the ground. But you must install a grounding jumper from the box to the fan.
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
running wires in a vaulted ceiling Did it myself Electrical 2 01-17-2009 07:37 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
ceiling fan installation PLEASE someone help finleygoddess7 Electrical 35 03-08-2008 09:41 PM
Ceiling fixture with odd set of wires hedbl00 Electrical 1 01-28-2006 09:11 AM
