Wires Running Into Receptacle And Switch Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 07:42 AM   #1
Rewards Points: 204
Wires running into receptacle and switch boxes
Do these have to be fastened to the studs? If so at what length from the box?
Thanks.
Abs777 is offline   Reply With Quote
Old 04-28-2010, 08:03 AM   #2
Licensed electrician
Rewards Points: 1,746
For boxes without a clamp you should staple within 8" of the box and then no more than 4 1/2' between staples. For boxes with clamps you can go 12" and then 4 1/2'.
Old 04-28-2010, 08:04 AM   #3
Electrician
Rewards Points: 800
In Canada it is withing 1 foot of the box and I beleive it is the same in the USA.
darren is offline   Reply With Quote
Old 04-28-2010, 08:17 AM   #4
Rewards Points: 204
My holes through the studs are 8" above the box. Will this work or do I need to staple too?
I used plastic boxes with the tabs that push in.
Last edited by Abs777; 04-28-2010 at 08:17 AM. Reason: I used plastic boxes with the tabs that push in.
Old 04-28-2010, 11:24 AM   #5
Electrician
Rewards Points: 800
If the box is below the hole the inspector probably will let it count, all depends on the inspector.
If the box is the next stud over from the hole then you would have to staple it within the 8" or 12" of the box before going through the hole.
Old 04-28-2010, 11:30 AM   #6
Knows everything but that
Rewards Points: 150
Just a quick, related question. Must these be staples or can one use the plastic nail in cable/wire holders? Thanks!
Shane
JakAHearts is offline   Reply With Quote
Old 04-28-2010, 12:50 PM   #7
joed's Avatar
Rewards Points: 13,288
If it is designed for NM cable then it is fine.
wiring receptacle form light switch olazu Electrical 8 12-03-2009 09:10 PM
Identifying wires in a three way switch bergs4 Electrical 15 07-29-2009 10:33 PM
ceiling lighting using electrical receptacle with no switch cedar Electrical 8 02-03-2009 06:00 PM
Switch / Receptacle mikbro Electrical 11 10-31-2008 04:15 PM
Adding a Hot Receptacle to a 3-Way Switch rtyui2 Electrical 11 11-21-2007 08:08 PM
