Wires Needed For 100 Amp Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 06:13 PM   #16
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Is there a solid answer for the OP?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
dfulton (07-22-2012)
Old 07-22-2012, 06:17 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The correct wire size was mentioned if he really wanted 100 amps...
The Following User Says Thank You to stickboy1375 For This Useful Post:
mpoulton (07-22-2012)
Old 07-22-2012, 06:39 PM   #18
Semi-Pro Electro-Geek
Rewards Points: 2,990
Yeah, and it's already been stated twice. The most solid answer is that NEC Table 310-16 sets forth the ampacities of different conductor types under different conditions - and don't forget thermal and conduit fill deratings if applicable. Nobody can really get any more specific than that without knowing all the details of the installation.
mpoulton is offline   Reply With Quote
Old 07-22-2012, 07:21 PM   #19
Missouri Bound's Avatar
Wire Size Calculator Use this to help make your determination.
Do you want it your way or the right way?
Garage Subpanel Wiring Question Joe85 Electrical 10 03-06-2011 03:14 PM
Help please - Upgrading subpanel! wtfh4xx Electrical 24 02-01-2010 05:55 PM
Surface Mount subpanel and 110/220 recepts - good idea? vsheetz Electrical 4 11-15-2009 10:29 PM
100 A Subpanel load help needed apparentgenius Electrical 4 11-11-2008 07:57 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
