Wires Needed For 100 Amp Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 10:03 PM   #1
I am running a 100 amp service to my workshop from my main house panel. I believe I need 2 #4, 1 #6, and 1 #8 wires. Is this correct?
220 feet from main panel. Buried - in conduit.
dfulton is offline   Reply With Quote
Old 07-21-2012, 10:26 PM   #2
Julius793's Avatar
No you need #3 copper or #1 aluminum.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 07-21-2012, 11:14 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,938
If he can use 90C terminations, then #4 Cu or #2 Al is allowed.
mpoulton is offline   Reply With Quote
Old 07-22-2012, 12:42 AM   #4
Rewards Points: 264
When I was researching doing my service upgrade, I ran across a number of folks stating that you won't find 90C rated equipment, unless it's rated for >= 600V. So I'm curious if you know of any 90C rated breakers that would fit in a standard residential panel.
a_lost_shadow is offline   Reply With Quote
Old 07-22-2012, 02:53 AM   #5
Electrical Contractor
kbsparky's Avatar
We routinely use #3 hots, #4 neutral, and #8 ground when installing THHN copper feeders for a 100 Amp panel.
#1 hots, #2 neutral, and #6 ground when installing aluminum XHHW conductors.
-KB
Old 07-22-2012, 07:58 AM   #6
Licensed electrician
Rewards Points: 1,618
You will not find residential breakers with a 90 degree termination.
Old 07-22-2012, 08:38 AM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I doubt you actually need 100 amps, so go with #2 AL, and feed with a 90 amp breaker....
Old 07-22-2012, 10:36 AM   #8
Julius793's Avatar
well i doubt he really needs 90a so go with #10 and a 30a breaker
Old 07-22-2012, 10:39 AM   #9
E2 Electrician
My suggestion was not to waste ones time trying to locate an odd ball size wire and just go with the next size down breaker and still feel adequate with the selection...
Old 07-22-2012, 10:40 AM   #10
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
I'm surprised no-one asked these questions yet...
Is the workshop connected to the house? How far away is it?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 07-22-2012, 10:51 AM   #11
Julius793's Avatar
you claim to be an electrician? ever walked into a supply houseand ask for #1 ser??? its just as avaliable as any other size!!!!
Old 07-22-2012, 11:09 AM   #12
E2 Electrician
Jealous of my knowledge?
Old 07-22-2012, 11:13 AM   #13
Julius793's Avatar
what knowledge??????
Old 07-22-2012, 11:18 AM   #14
Julius793's Avatar
conduit or direct burial?
Old 07-22-2012, 11:18 AM   #15
E2 Electrician
Bwaahhh, i'll leave you to yourself.
Garage Subpanel Wiring Question Joe85 Electrical 10 03-06-2011 03:14 PM
Help please - Upgrading subpanel! wtfh4xx Electrical 24 02-01-2010 05:55 PM
Surface Mount subpanel and 110/220 recepts - good idea? vsheetz Electrical 4 11-15-2009 10:29 PM
100 A Subpanel load help needed apparentgenius Electrical 4 11-11-2008 07:57 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
