Wires Leaving Panel Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 09:49 AM   #1
Rewards Points: 212
Wires leaving panel box
Is there a rule that says all wires exiting the panel box must be directed in a specific direction? A lot of pictures of panel boxes show the mains at the bottom and all wires going upwards. If you have a panel box on the first floor, and you have an open ceiling in the basement /crawl space, could you add a new circuits (washer/dryer) with wires down from the panel box into basement, and along perimeter to a location, then up to a new laundry area?
I realize that breakers, wire gauge, staples, boxes, receptacles must all be done properly. This is just a question about direction of the wires exiting the panel box in a situation where there are finished walls and ceilings.
orange is offline   Reply With Quote
Old 05-19-2009, 09:53 AM   #2
Rewards Points: 2,350
No, there is no rule. Run the wire through the crawl space if that is easiest for you.
Old 05-19-2009, 10:13 AM   #3
Rewards Points: 212
Thanks for the quick response.
Old 05-19-2009, 12:54 PM   #4
I like to run conductors out the bottom to get a gravity assisted flow of electrons. It helps cut down on utility costs.
220/221 is offline   Reply With Quote
Old 05-19-2009, 12:57 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
Haha but the current has to return "up hill" back to the panel. Just remember, if you tie a knot in your wire/cord it will stop the flow of electrcity. And likewise if you take the cover off a piece of equipment and turn it over you'll dump all the electrons out.
theatretch85 is offline   Reply With Quote
Old 05-19-2009, 01:27 PM   #6
Rewards Points: 346
As important as the electrons are it is the smoke that makes all electronics work... To prove this just let the smoke out and see what happens!!!
RegeSullivan is offline   Reply With Quote
Old 05-19-2009, 02:36 PM   #7
Chicago, IL
Michael Thomas's Avatar
Originally Posted by orange View Post
A lot of pictures of panel boxes show the mains at the bottom and all wires going upwards.This is just a question about direction of the wires exiting the panel box in a situation where there are finished walls and ceilings.
Conductors can exit the panel through any knockout (and you can buy tools that let you make additional knockout size holes in appropriate locations elsewhere in the panel). The principle practical limitation is the allowable bend radius of the conductors, which is sometimes an issue with large conductors used to supply power to a panel or send it from one panel to another.
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
price for hooking up panel wires apeman76 Electrical 7 08-14-2007 02:04 AM
